Question about Moulinex Brio IM3070 Iron with Auto Shutoff
Moulinex brio 50 iron - Moulinex Brio IM3070 Iron with Auto Shutoff
When i iron brown liquid is coming out has ruined a lot of white tops cannot get it out
This is caused by deposits that are in the water you are using. Empty the iron and fill with a 50-50 solution of Vinegar and water. start it up and iron on some rags for about 5 minutes ho the highest steam setting use the sprayer liberally. Empty the iron and repeat until you see no mor deposits on the rags. Then use only distilled water in the iron.
Apr 19, 2011 | Russell Hobbs 14033 Iron
How to feel water in iron??couldn't find opening way?its Moulinex iron
To fill an iron which doesn't appear to have an opening with water - such as the moulinex chronomate 35 - you need to pull off the sprayer button. That should reveal the opening!
May 04, 2010 | Moulinex Brio IM3070 Iron with Auto...
Lost the details on how to clean Philips GC2540 iron. Please can you provide some information.
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 18, 2009 | Philips Irons
Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Oct 06, 2009 | Rowenta Irons
STEAM ONLY COMING OUT OF TOP HOLES SWAN S15040
The iron is probably clogged up from mineral deposits in the water. Fill the iron with a 50/50 mix of water and white vinegar. Heat the iron and let it set for awhile. Then steam the solution through the iron. Repeat the process if this does not work. If the Vinegar and water does not work, then try a product such as Lime Away or CLR to remove the deposits. After the iron is cleaned out, try using distilled bottled water in the iron, to reduce the mineral build up.
Hope this helps you!
Aug 15, 2009 | Black & Decker Steam Generator SG200 Iron
Iron not steaming
clean with 50/50 white vinegar water let soak overnight then flush out!!!! :)
Jul 06, 2009 | Rowenta Steam Generator DG050 Iron
Gunk coming out of iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.
Mar 29, 2009 | Irons
Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Nov 15, 2007 | Irons
Moulinex Brio IM3070 Iron with Auto Shutoff Logo
Top Moulinex Irons Experts
Are you a Moulinex Iron Expert? Answer questions, earn points and help others
