Question about Acer AL1511 15" LCD Monitor
Can't seem to remove the back of my Acer 1511s. There are two screws at the bottom which are easily accessible but can't see any others. The front cover is anchored firmly at the top corners and at the bottom where the controls are.
  • chastitybelt Apr 24, 2009
    Sorted it!
    There's a cover where the pedestal bracket attaches to the back of the monitor. It comes off to reveal four hefty screws.
    Disassembly was a doddle after that.
    The fault, by the way, was a blown 240v fuse in the power supply caused by a shorted bridge rectifier, which I replaced with a higher power version.
    All is now well and I can have a cup of tea.
    Charles.
    Genius:
  • 1,550 Answers
They got plastic secures and need to push out with a flat screwdriver between two covers
Posted on Apr 24, 2009
How do i remove the screen to my Mitsubishi wd-62638
For the model indicated (WD-62638) the entire screen unit needs to be removed.
Some models had two mirrors--the usual large one in back and a tiny one in the bottom front.
1. Locate and remove front plate below screen (where you may access the lamp as most of these are taken out from front)
2. Remove all the screws ON THE BACK OF THE SET around the top and both sides.
3. Remove a plate behind the removed lower front grill and there you should find a set of wires that go to front keyboard.
4. With that done look carefully at either front side below the screen unit---one screw on either side---do not remove but just back them out.
5. 2 person job---the entire screen unit lifts up and out.
6. DO NOT try to clean the large mirror---if touched with hand or your hair it will smudge and it will show in the picture.
7. If the little mirror is there at the bottom---it can be cleaned with glass cleaner---
8. Insert the screen unit back with the two front lower screws supporting it (have someone hold it in place until you line up and install all all the rear and then the 2 front screws.
Let me know if you have questions.
Mar 10, 2012 | Mitsubishi WD62628 62" Projection HDTV
Drain wont drain on a epic washer where is the drain filter located at
The drain filter is located in the pump behind front bottom panel. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly.
Nov 14, 2010 | Maytag EPIC MFW9700S Front Load Washer
Have a foriegn object in the pump and i need to get thefront bottom panel off so i can acess it
Disconnect power and remove the three screws attaching the bottom flange of the lower front access panel to the cabinet. Once the screws are removed, pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Remove the pump filter by turning the knob counterclockwise and pulling the filter out. Make sure to catch residual water from the filter housing by placing a shallow pan or a piece under the filter housing to avoid flooding your floor.
Sep 09, 2010 | Kenmore 45981 Washer
How do i take my Acer Aspire 5532? i want to replace the processor, but the gut's are like a poorly designed obstacle course. :(
Usually the first thing on a laptop is the keyboard, then pry the plate above the keyboard (between lcd and keyboard), this will give access to the lcd hinges and connection. Remember to remove all screws, covers, drives, battery, memory and ethernet card BEFORE taking anything apart. Unplug the lcd, pull the wireless antenna wire through from the bottom of the laptop then remove the lcd. make sure there are no screws through the case from the top. then you simply pry the top off the bottom, be sure to start from the back as the front of the aspires are usually hinge style clips-meaning when you put it together tilt the top toward you, slide the front clips in place locking the front down then press down on th edges from the front to back to snap it together). After the top is off remove screws from the heatsink and fan, disconnect the fan and remove heatsink. There you go, install opposit of removal.
Jan 24, 2010 | Acer Aspire 5315 Notebook
Finding the bios battery on a acer 5103WLMI. I removed all the scerws I cud see but the two bits wound not part and I do not wont to forc then help
I am giving you a link to the service manual below. All laptops will disassemble in different ways and there seems to be an infinate number of manuals to explain. Most older Acer laptops do not have the RTC battery in an area easily services by the home user, usually you have to take the plamrest assembly off, Acer laptops usually pivot from the front of the laptop, therefore you have to lift up the edge nearest the screen and pull it up that way and disconnect off the front. Also, there are more than screws that hold these together, acer uses small tabs along the edge and back and sometimes uses hex screws on the bottom of the motherboard, these are used to mount expansion cards. Below is the link.......
http://tim.id.au/laptops/acer/aspire%205110%205100%203100.pdf
Nov 15, 2009 | HP Pavilion dv6000z Notebook
Replacing the power supply in a Acer Aspire RC500
Replacing power supply is simple.
1. unplug power,monitor,kybrd,mouse,printer...etc.
2. remove cover
3. while hold case unplug power from drives, and motherboard (only those connected to power supply).
4. remove screws attaching power supply to case.
5. remove power supply.
To install new power supply just follow in reverse what you just did to remove it.
Mark
Mar 29, 2009 | Computers & Internet
How to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Jan 26, 2009 | Hotpoint WMA58 Front Load Washer
Have acer notebook aspire 1410 cant get case appart
remove all visable screws on bottom of pc,remove battery and covers remaining screws are hidden in such places,remove screws at back behind screen to lift front panel and access keyboard removal.depending on model access to panel with mouse pad is done after keyboard lifted.
Mar 08, 2008 | Computers & Internet
MEMORY UPGRADE ON ACER TRAVELMATE 5720G
Acer's support isn't the best. IMHO But go to their support site anyway and look up your laptops manual (there should be instructions on upgrading your RAM there). I did find that your machine will accept up to 4GB of RAM 2 X 2GB sticks. There should be a door or port (for easy user RAM upgrading) that is being overlooked, but again it is an Acer.
Good luck.
Feb 23, 2008 | Acer TravelMate 2300 Notebook
Tom tom rider
I made a video on how it open your TomTom rider.
Feb 09, 2008 | Tomtom RIDER GPS Devices
Acer AL1511 15" LCD Monitor Logo
218 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
