Question about JVC LT-32E488 32 in. LCD Television
Factory reset press
Do not have the parental code
  • 26 Answers
Here is a link to the User Manual in PDF format. http://resources.jvc.com/Resources/00/00/91/YA512ien.pdf
Page 35 tells how to set a new code. The default code is 0000. It also says that if power is lost a new code must be set. So, perhaps you could simply unplug/plugin and see if code is set to 0000. If not, then read page 35.
Posted on Oct 15, 2013
    Sergeant:
    Champion:
  • 201 Answers
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes preset
with a lock code of 0000 You may change the code to any four-digit number you wish. To
change the lock code, follow the steps below.
Press the MENU button
To "Initial Setup"
To enter
To "Set Lock Code"
To operate (Password input screen will appear)
Enter the password by using the 10 button
keypad
The Set Lock Code screen will appear
To set the password, use the 10 button keypad
Press the OK button to finish your lock code is now set
How do u get parental passcode
Try a reset
To restore the TV to its factory default settings:
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight System
and press OK. The SYSTEM menu is displayed.
3. Highlight Reset & Admin and press OK. The RESET & ADMIN
menu is displayed.
4. Highlight Reset TV to Factory Defaults and press OK.
5. If you have changed the default parental control PIN, enter it
now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults."
6. Highlight Reset and press OK.
7. Wait for the TV to turn off. The TV will turn back on shortly.
If you have not set a PIN, enter the
default, 0000
Feb 14, 2016 | Vizio E-Series E470I-A0 47" LED TV...
How do i bypass the parental control on a kindle fire hd
Either enter the parental control password or factory reset the tablet. Power off the tablet, press the power then press and hold power and either vol up or vol down to get the boot menu. Choose the factory reset option.
Nov 18, 2013 | Amazon Kindle Fire HD
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Password to delete or change parental code
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press
left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
THEN immediately afterwards, press DOWN, Y, UP, DOWN
This should bring up a menu
Reset System Settings
Resetting your system settings
will return all console settings to
factory defaults. Do you want to
reset to factory defaults?
Yes, reset settings
No, don't reset settings
select to reset settings
your screen should go blank for about 2 seconds
then the language blade should appear that lists several different languages,
select your preferred language
then a blade that says "Xbox 360 Storage Device" should appear
With the options of,
Done
Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear
with the options of,
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
Dec 23, 2008 | Microsoft Xbox 360 Console
Cant remember parental control code.
All Details Below On How To.
restart 360 Unit
press
Yes, reset settings
Done
Family Settings
Xbox Dashboard
Jun 25, 2008 | Microsoft Xbox Console
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Parental control is stuck
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Oct 03, 2006 | Daewoo DTQ-19V1FC 19" TV
JVC LT-32E488 32 in. LCD Television Logo
364 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
