Question about Mitsubishi WD-73827 73" HDTV DLP TV
My Mitsubishi 73" DLP won't turn on. - Mitsubishi WD-73827 73" HDTV DLP TV
  • 416 Answers
There could be several reasons, If you have Warranty, best would be to take it to the point of purchase.
Posted on Oct 15, 2013
4 Suggested Answers
  • 98 Answers
SOURCE: Where can we buy a light engine for our Mitsubishi
From Mitsubishi parts, 18005537278.
Posted on Jan 18, 2011
gopakumarg43
  • 75581 Answers
SOURCE: TV is 73" DLP Mitsubishi.
Hello
There are tow reaons for this fault. The first one is with the colour whell as you mentioned here. The second and most importan one is with its bulb itsef. Colour wheel won't cost too much. Just replace it first and see whether it helps you. If not, bulb may have to be replaced.OL
Posted on Jul 31, 2011
pimptwzt
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Posted on Dec 24, 2012
I am getting wide lines of bars on the screen after replacing dlp chip in wd- 73735 73" mitsubishi
you will need to pull the DLP chip out & clean the dust & foreign particles that got in while you had it apart.
Mar 11, 2015 | Mitsubishi WD-73735 73-Inch 1080p DLP HDTV
73 inch tv speakers are off how do you turn them on
Go to menu and click on sound on this click to see if speakers are turned on if not click on if that doesnt work try the try the return to factory settings..
Jul 14, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
What is a dmd on a mitsubishi 73" tv
Howdy Mike-d. here,
I do not know what a DMD is on a Mitsubishi 73'' TV.
I did do a little web searching and here is a couple of things I came across.
From this website: http://www.tvserviceparts.com/Mitsubishi_DMDChips.html WD73833 ALL 4719-001997 DMD Chip, DLP, 1920X1080/XHD5, 0.65"/ DC4, TYPE X NON
I have no ties to these websites.
"I researched this and it was a DMD chip that needed to be replaced."
from this website: http://www.consumeraffairs.com/home_electronics/mitsubishi.html
Hope that helps.
Mike-d. out
mikedee4@gmail.com
Mitsubishi TVs and Electronics Mitsubishi TV DMD DLP Chip
Jun 27, 2014 | Mitsubishi WD-73833 73" HDTV
Mitsubishi wd-73c9 73" dlp tv
Here's what the Manual says about light codes for this TV. See Picture of actual page from manual.
Apr 13, 2014 | Mitsubishi WD-73C9 73" DLP TV
Mitsubishi 73"DLP wd-73638 won't turn on after power outage or getting unplugged
In most cases, this can be due to curropted software [firmware]. Contact the authoriized service center for Mitsubishi. Please do not try to update the software by yourself. It is a very skilled work to this set. Gopakumar Gopalan Google
Feb 24, 2014 | Mitsubishi Televison & Video
73 mitsubishi dlp tv 73737 has sound but no picture with red light in frount
You need a new lamp. The red light means the lamp failed to turn on.
You can find cheap ones on ebay for about $40. If you go to best buy they will charge an arm and a leg. You can change the lamp yourself and it will take less than 15 mins to do. The only tools youll need are a phillips screw driver and maybe a flat head.
Jan 26, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 1080p dlp hdtv troubleshoot
If it's older. Probably a blown lamp. Check owners manual then shop,new one on eBay. Easy to replace. I have done it twice
Sep 27, 2013 | Mitsubishi Wd-73733 73-inch 1080p Dlp Hdtv
My tv turns blue and turns itself off
optical block assembly going bad. repair is pretty costly. try vacuming out the fans. DO NOT USE CANNED AIR!!!! you will blow all the crud into the optical block.
Jul 12, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
227 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
