Question about Alpine Type-R SPR-17LP Coaxial Car Speaker
Witch is the negative and positive tabs on these speakers Alpine Type-R SPR-17LP Coaxial Car Speaker 6.5"
blueextc3221
  • 15935 Answers
SOURCE: How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Posted on Jan 12, 2009
etirbynnor
  • 655 Answers
SOURCE: positve and negative speaker wires for 2008 chrysler aspen
Hello latinoheatj5,
According to modified life.com the speaker wire colors for the 2008 Aspen are:
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
You can go to their web site here for other radio wiring color codes.
http://www.modifiedlife.com/2008-chrysler-aspen-car-stereo-wiring-diagram/
Posted on Mar 31, 2009
omaromid
  • 332 Answers
SOURCE: whats the best alpine 6x9? dds-r69g,sps-6939,spr
All of these work nice, remember the quality of the sound depends primarily on the source ( car stereo and/amp) and then the speakers, you need to know what Ohm and what watt is the minimum requirement for your sound system.
Posted on Feb 07, 2010
  • 5603 Answers
SOURCE: i wired my alpine sws-1243d and in a matter of 3
The polarity of speaker connections verses the connection to the amp should have nothing to do with situation. The sound reiforcement would be weaker in one direction is all.
Make sure the amp was not rated for more power than your speakers. If you overdrove the speakers you may have fried the voice coils.
Posted on Feb 08, 2010
pctech1
  • 1940 Answers
SOURCE: which blade on sps-600c speaker
The wide terminal is the Positive +, and the thin terminal is the Negative -.
Posted on Jan 17, 2011
I have a alpine CDE 152 head unit in my car and just put in alpine SPR 60 coaxial speakers in the rear. thought the head unit would be enough and want more punch from the base.. do i need an amp or i
get the alpine ktp445 mini amp ,it should be compatible (check your manual for your HU it will say ) its a plug and play install and you will hear a great improvement as I did and still got mine with the alpine cda 117 .
Apr 04, 2014 | Alpine Car Audio & Video
Spr-69 crackling
It may be a bad voice coil. It would make that type noise. If the cone isn't cracked its the coil.
Jan 25, 2014 | Alpine Type-R SPR-69 Car speaker - 100...
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
I need the wiring diagram to install a Alpine 7516 in a Dodge Colt 1994.Thanks! Alain
1994 Dodge Colt Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Red/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/White
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/Green
The manual for the Alpine 7516 can be purchased here:
https://www.samswebsite.com/en/photofact/search/index/model/7516
Jul 19, 2010 | Alpine Car Audio & Video
Can an equalizer cause hissing
The more ground the better,or check the RCA cables.or to see if the power wire is running any cables that power the inter.
Oct 26, 2009 | Alpine Type-R SPR-17LP Coaxial Car Speaker
Speakers quit
check ur wires and make sure ur ground is good.be sure u have the neg. and pos. rite all threw the car
Jun 18, 2009 | Alpine Type-R SPR-69LP Coaxial Car Speaker
Positve and negative speaker wires for 2008 chrysler aspen
Hello latinoheatj5,
Mar 31, 2009 | Alpine Car Audio & Video
Hissing in speaker
I would contact http://www.simplyspeakers.com amd see if theres a repair thats feasable to do with this speaker and tell them what you got and what you wanna do and they will assist you in getting the speaker fixed or replaced with what you want and for the price you want. Good Luck
May 12, 2006 | Alpine Type-R SPR-17LP Coaxial Car Speaker
Alpine Type-R SPR-17LP Coaxial Car Speaker Logo
50 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
