Question about Honeywell Street Smart Code Encryptor II Remote Fob CEREM
Programming a street smart key fob - Honeywell Street Smart Code Encryptor II Remote Fob CEREM
2007 Harley Davidson FLHX Street Glide key fob not working
Hi, Leonardo starting in 1996 Harley made available an optional security system with a Button Key Fob that had to be depressed to arm and disarm the system. In 2007 the smart security system was introduced in European countries with a buttonless proximity sensor Fob that only works within a 10-foot radius depending on battery strength and sensor receiver location. In 2012 Smart Security Systems became standard equipment on some models. In 2015 it was standard on all models. The following is a list of security system FOB failure:
BUTTON FOB'S
1. The FOB battery is weak or dead.
2. A new battery was installed upside down.
3. The FOB is no longer recognized by the security system and needs to be reprogrammed by the dealer.
PROXIMITY SENSOR FOB'S
1. Fob is more than 10 feet away from the bike.
2. The FOB battery is weak or dead.
3. A new FOB battery was installed upside down.
3. The security receiver antenna is broken.
4. The FOB is no longer recognized by the security system and needs to be reprogrammed by the dealer.
There is an option to override the security system by inserting a pre-programmed pin number. This is a 5 digit number that comes from the factory as 1-2-3-4-5. If you read your owners manual it "HIGHLY" recommends that you change this number to a personal one. You can do this yourself but it is complicated and tricky sometimes it works sometimes it doesn't. I have a 2003 FLHTCUI that the procedure did not work and had to go to my local dealership to have the system reprogramed to my own personal number. They wanted $50 for this 2-minute service but after explaining that I was a 40 year retired Harley wrench and waving a $20 bill to the service writer got me through. Money talks but not all the time.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Security System 2007 Street Glide Harley Davidson Forums
Find your Harley Davidson securty PIN code number
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
2008 Harley Davidson Touring Models Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/007-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally for only a mere $6
Apr 24, 2018 | 2007 Harley Davidson FLHX Street Glide
Hello I have a 2006 scion tc I was driving down the street and it died and now it won't start I turnd the key on all the lights come on but it won't do anything
your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.
Jun 16, 2015 | 2006 Scion tC
Saab experts
May be keyfob needs reprogramming.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Peugeot 206 key fob
Try with brand new key fob battery and see.If that helps.
Otherwise May be keyfob needs to be reprogrammed.
KEYFOB PROGRAMMING
Thanks.
Nov 28, 2012 | Peugeot Cars & Trucks
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
Nov 23, 2012 | 2006 Toyota Tacoma
Key fob opens garage doors but wont trigger alarm
It should be possible it depends on what type of panel you have on how you would program it. If you open the metal box that houses the panel it should be listed somewhere. It might be on the door but beware some metal boxes have different panels in them sometimes. Look on the board itself for a white sticker that has numbers and or letters on it.
Oct 09, 2012 | Honeywell Street Smart Code Encryptor II...
Alarm system for 2005 heritage softail deluxe
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
SMART Key Fob Programming
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 20, 2012 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
How to program a FOB for a harley davidson
Mar 28, 2012 | Harley Davidson FXR Super Glide...
Replaced chip on key on 91 DTS and car lost all power while driving. It shut down and nothing works.
There are 4 methods for programming key fobs. Up to 4 key fobs may be programmed to the remote control door lock receiver (RCDLR). Each programmed key fob is given a position of #1-#4 in the RCDLR memory.
Method 1 - Key Fob Quick Learn This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
The vehicle must be OFF.
Place a known key fob within the interior of the vehicle.
Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4).
Place the replacement key fob in the console fob pocket with the buttons facing forward.
A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED.
If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode.
Operate the active portion of each key fob in order to finalize the programming sequence and verify correct system operation.
Method 2 - Key Fob Slot Programming
This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Install a scan tool.
Use the scan tool, to access the following:
• Vehicle Control Systems
• Computer/Integrating Systems
• Module Replacement/Setup
• RCDLR
• Program Key Fobs
Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to.
Place the replacement key fob in the console pocket with the buttons facing forward. A beep will occur indicating programming completion. The previously known fob is now erased.
If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming.
Remove the scan tool.
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10-minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicle mechanical key.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
The DIC will display a message: OFF/ACC TO LEARN.
Press the OFF/ACC portion of the ignition button.
The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time.
When the counter reaches 0, DIC will display OFF/ACC TO LEARN.
Repeat steps 5-7 two more times, for a total of 30 minutes.
A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2.
Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Method 4 - Service Programming System Fob Programming
This procedure is a 10-minute relearn procedure using the Techline Terminal with SPS software. Once the 10-minute timer has expired, the fobs can be programmed similar to Method 2 using slot programming. A scan tool, Techline Terminal, and a replacement key fob are required to perform this procedure.
Place the vehicle in the Vehicle On, Engine Off mode.
Connect a scan tool to the vehicle.
Insure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
Turn the vehicle OFF.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10 minute relearn procedure.
When the 10 minute relearn procedure has completed, use the scan tool to access the following:
• RCDLR
• Program Key Fobs
If programming additional key fobs, repeat steps 12-13, or press the OFF/ACC portion of the ignition switch to exit programming.
Oct 26, 2011 | 2006 Cadillac DTS
Smart key
Montie,
The problem that you have in this situation is that all smart keys are registered with a unique identification code specifically coded to your vehicle. So, if you purchased the key from a junk yard for a different vehicle and VW would not code that key for your vehicle it will not work on your vehicle. There is no other way to make that key work for your vehicle if VW will not program it to work for your vehicle. Most locksmiths do not even have access to the codes needed to reprogram the VW key fobs.
My suggestion would be to fork over the $50-$100 bucks for a new key fob from VW. They will most likely need your PIN that is assigned to your vehicle. They can also find this information out by running your VIN number or hooking your car up to the diagnostics system at VW.
Hope this info helps.
Oct 17, 2008 | 2006 Volkswagen Passat
Honeywell Street Smart Code Encryptor II Remote Fob   CEREM Logo
147 people viewed this question
Top Honeywell Home Security Experts
Steve
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
