Question about Bosch PB360D Deluxe Power Box Jobsite Radio
When i put a bat609 batt in unit it kills the battery happened 3 times whats wrong?
  • 26 Answers
Looking on the Bosch.com site, the specs show there are different models of the PB360D and they use 4 different size and voltage batteries; 14.4v and 18v. SlimPack and FatPack. The BAT609 is 18V SlimPack. Perhaps you need the BAT607 which is 14.4V SlimPack. Best way to tell for sure is go to Boschtools.com. At the bottom of the page, go to "Spare Parts". On that page, enter the 10 digit model number of the radio and it will tell you the correct battery.
Posted on Oct 15, 2013
2006 liberty new battery alternator works when sets over night battery goes dead put a kill switch on and still goes dead ?
Hello Jr, The fact that the battery goes dead even with a kill switch would lead me to think the new battery is defective.
Mar 03, 2015 | 2006 Jeep Liberty
Cluster not working
you have taken the battery off wrong it negative off the battery first, then the positive wire. taking off live wire first then butting it back on will blow a number of things even the ecu/ abs units.
Apr 11, 2013 | 2003 Chevrolet Cavalier
I try to turn my lg50pj350 on and it trys to power up 3 times but nothing happens
YOUR CHARGERS OUTPUT IS NOT PROPPER VOLTS OR POLARITY IS WRONG MOST LIKELY WRONG CHARGER POSSIBLY BAD BATT CHECK MAKE SURE CHARGER IS PUTTING OUT VOLTAGE SOME TIMES GOTTA WIGGLE PLUG SOCKET OR WRONG TYPE OF PLUG. HOPE THIS HELPS
Sep 27, 2012 | Cars & Trucks
Bike will start but it kills batt after it's been
One highly possible issue could be that you may a sheared generator coupling, it connects the start gear to the generator to keep the battery charged. This happened to my RF and is somewhat common.
May 20, 2011 | 1996 Suzuki RF 900 RS2
Battery light stays on.
If you disconnect the battery for 20 min it should kill all memory and reset everything.If not you charge is still low charge up your batt. with a charger.and test your alt. output 13.9-13.7 you have to check the book.I'm not to sure on that.You might have a voltage regulator problem bad batt. Or somthing is hooked up wrong. Mabey the old alt was fine. Have the batt. tested. All alt. well most are rebuilts so you might have a bad one it happens.Make sure that it's putting out a charge.
Loose alternator drive belt or loose or corroded battery cables. The battery itself may also be bad.
Sep 22, 2009 | 1998 Chevrolet C2500
2007 Hyundai Elantra has to be jump started. Battery is fine
from your comment,theres 3 things that can cause this,loose batt.post connection,weak batt.or something in elect. circuit that stays on after car is off and drains batt.,like underhood light,dome or truck light,what u can do is when u park car unhook batt. cable,make sure batt. is well charged,hook it up next day if car starts,its something that drains batt.in car! if it doesnt start,batt. needs replacing.i ruled out starter,dealer should have checked it to see if it was pulling too much amps,and that its easy to jump.
Mar 29, 2009 | 2007 Hyundai Elantra Limited Sedan
Alternator not charging idiot light off
sound voltage regulator. you need 13.5 14.5 to charge battery .12.volts not enough. dash light warning light bulb could be burn out.
Mar 06, 2009 | 1991 Nissan Sentra 2 Door
Sennheiser SK 100 Bodypack Transmitter won't power up.
Hello. I Am Not Familiar With This Exact Model, But I Have And Still Do Own A Number Of Wireless Units. There Are A Number Of Things That Can Go Wrong, But If The Unit Wont Power Up, I Would First Check The Battery Compartment For Loose Battery Connections. Over Time They Can Weaken Or Just Get Bent The Wrong Way. Then I Would Look For Loose/Unsoldered Wiring. I Have Encountered Many Cases Where The Battery Compartment Contacts Become Loose , Or The Wiring Going To It. Good Luck
Nov 06, 2008 | Audio Players & Recorders
Will someone help me?
If you have read the user manual on page 16, this camera only compatible with two kinds of batts: alkaline or rechargeable batts.
Mar 30, 2008 | Fuji FinePix A900 Digital Camera
Bosch PB360D Deluxe Power Box Jobsite Radio Logo
Top Bosch Audio Players & Recorders Experts
wayne-m
Bill Boyd
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
