Question about Frigidaire Ovens
The wrench light has come on and now the oven will not turn on
  • 416 Answers
Wrench lights means that it needs to be checked by a technician. If you still have warranty, refer to the point of purchase
Posted on Oct 15, 2013
How to change the light bulb in a maytag 8114P732-60 oven
Hi Mary. I had a bad bulb in my Maytag new from the factory. I also had a hard time getting the glass lense cover off, and didn't want to be too rough with it for fear of breaking it. But it WILL come off if you turn it hard enough. I've since seen suggestions about putting warm water on it to loosen it up. And another person wrote and said using an oil filter wrench on it worked like a charm.
Good luck
Jul 27, 2014 | Maytag CWG3100A Gas Single Oven
How do you remove light bulb cover?
Just twist it off. I know that is easier said than done because they can be a pain. But if you turn it hard enough it will come off. I've seen suggestions about putting warm water on it to loosen it, an another said using an oil wrench on it worked like a charm.
Good luck
Jul 14, 2014 | Maytag CWE4800A Electric Single Oven
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Trying to change Maytag Gemini from natural gas to Propane. Have orifices, but no diagram of where they are located.
take the covers off the burners and look, the jets are near the burners, small wrench to turn them out and replace with the other jets. the oven is a different story, and depending on you model may not even have jets that can be replaced, rather you adjust the one jet that's in there by turning it with a wrench (you should have gotten a book that helps with this)
Mar 19, 2011 | Maytag Ovens
Can't keep the pilot light lit.
Your safety valve is bad. You could try repositioning the thermocouple probe but bootm line is these cannot be repaired they must be replaced. The new safety orifice ain't gonna be adjusted you will have to do that.
Match the height of the old one with the new part by turning the orifice with a nice fitting wrench post your model number so I can look up just what you have. Checking oven safety valve: HERE72a2330.gifa7f3db4.jpg
Apr 04, 2010 | Ovens
Why does the Oven take so long to light?
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
I cannot remove the oven light cover in my Whirlpool gas range.
Put on a rubber 'serving' glove or dish washing glove and it will give you some traction to grip the glass to turn it
Sep 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Can not remove light bulb from whirlpool oven
I had similar difficulty. This worked for me after 45 mins grief.
I got a heavy duty 1cm wide elastic band (length double was about 14-15cm). This is a common size heavy duty elastic band in the UK.
This elastic band is much too long to go around the glass bulb cover so I tied a knot in it so that i had a complete circle of rubber band tightly held around the bulb cover. Then I used a Mole wrench -a kind of large adjustable spanner - to undo the glass bulb cover. It came off easily because the rubber band gave sufficient grip to undo it. It is about 2.5 full turns anticlockwise to completely free it.
I hope this will help the next viewer of this website.
Geoff
Aug 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Cant remove oven light cover
Try a adjustable car oil filter wrench (cost a couple of bucks at Wal-Mart). Simply put it around the glass cover and give it a twist. Worked great for me.
Nov 12, 2008 | Ovens
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
