Screen will not function. No video at all.
Just bought new LG R710 laptop, and screen will not power-up. No video, only audio. The manual that came with the system is primarily French, and contains little info. Any suggestions???
Pls.. help me i have a samsung r710 it does not have any display at all when i switch on the power the power have light but there no display i try to dismantel it but no luck at all. pls help me to solve this i just need this loptop of mine you can e mail me at chrix1us@yahoo.com tnx to all ......
Posted on Sep 05, 2011
  • 45 Answers
Here's what you can do.
it might be blank due to the togle feature so try this
***'Monitor Toggle Features (Converting the Screen Using the Shortcut Key) If you have an external monitor connected to the computer, press Fn + F7 keys to rotate the display mode between LCD only, Monitor only, and LCD + Monitor both in order.'***
as long as you hold Fn and press F7 these mode's will change in order respectively.
if the issue was due to the inappropriate display mode it can be fixed by toggling.
since your display is totally blank... you need to find out weather it is the screen or the video card in the notebook. either ways if hardware is faulty your guarantee should cover it.
In case, you are looking for Manual in English you can find it by googling up your Notebook model number.
If the issue were with the display adpters or drivers then you can fix them by connecting and toggling to external monitor.
Posted on Apr 24, 2009
When the power is turn on the screen shows unlock
You might have inadvertently engaged the lock function and now waiting for password. Refer to
the manual how to reset.
Mar 22, 2014 | Sony Str-k850p 7.1 Digital Home Theater...
I've tried to connect my laptop to a projector but i just get the information projected but cant be seen on my screen of the laptop
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
Mar 21, 2013 | Acer Aspire 9300-5349 Notebook
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
Philips blueray player not working with lg smart tv
If you press play after welcome screen, you should see picture.
Jan 18, 2018 | Philips Televison & Video
It went black but the power is still on
Computer Crash
One of the more complicated reasons why laptop screen goes black is a crash. This could occur for a variety of reasons and is often very difficult to fix. You will have to take the machine to a computer repair shop, and they will open up the laptop there to find the cause. Needless to say, this could set you back by a few hundred dollars as well. The crash could be caused by overheating, or maybe even a loose power supply cable. One solution for you is to play an audio file if the laptop screen goes black. If it does not play at all then something is wrong with the entire system, but if the audio file plays then it is just the laptop screen that is troubled.
Virus
There are a few computer viruses that can cause this problem, but most antivirus programs can effectively deal with such a virus. Update your antivirus software regularly and make sure you download all possible firmwares, and this sort of virus will be successfully thwarted. If your machine is infected with such a virus then your video drivers will most certainly be affected, and even your video card could get contaminated. All this results in your computer screen going black, and in some instances, your laptop screen may even go blue.
Drivers and Programs
The video drivers are crucial for making the computer monitor function properly. On some occasions though, these programs can stop functioning due to some reason. If your laptop screen goes black after startup on a consistent basis, then maybe it is your video drivers that are malfunctioning. To avoid this situation, you should constantly upgrade your video drivers, and should also refrain from using pirated video drivers. Spend those extra bucks on getting licensed drivers, and you will save a lot of unnecessary expenditure in the future. Read more on how to upgrade laptop video card.
Jan 06, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
How do I connect an Additional LG monitor to my notebook
Follow these steps :
1.
Check whether your monitor has a DVI (digital) or VGA (analog) port, both of which are generally built in. Contact your vendor if your laptop does not have either. In this case, you can use a special adapter to connect the external monitor. These adapters are model specific and should be bought directly from the vendor.
2.
Connect one end of the DVI or VGA cord to the DVI or VGA port of your laptop and the other end to the monitor. Your laptop should automatically identify the external monitor as a new hardware device.
3.
Most laptops will show the desktop on both screens by default, which is known as the mirror view. You can use function keys with common combination such as Fn + F2 to toggle between the two screens. Refer to the laptop's user manual for the right key combination to toggle between the displays. Alternatively, with many laptops you can also switch to the extended desktop mode. This means your desktop screen will be stretched across both the monitors. Refer to your user manual to switch to this mode.
Oct 30, 2010 | LG Computers & Internet
Audio video locks
Get the user manual first and go to page 76 for instructions on how to remove the locks in it.
Apr 07, 2008 | LG 42PX5D 42 in. Plasma HDTV
Monitor automatically clicks into power saving mode
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
