Question about Husqvarna Garden
Braking system can not get plate back on saw - Husqvarna Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You engaged your brake while it was off... needs to be disengaged and it's not easy to explain...
Posted on Oct 20, 2013
What rear brake backing plates can i put in a 1956 ford f100?
check around as some sedans have the same rear brake setups as the f100. Cruise the wreckers (ford specialists) with your backing plate and find a backing plate same as yours from any sedan around the same year as yours.. Brake capacity is calculated on vehicle weight and as manufacturers are reluctant to spend money on developing new brake systems they tend to use the same parts on as many different models as possible.. Another thought car manufacturers use brake systems built by brake specialists like Bendix and Ferrodo and others so check other makes (dodge,chrylser even the chev range for a possible match of brake assemblies in that year.
Sep 08, 2014 | Cars & Trucks
How to fix the back plate of the drum rotor on a 2006 Dodge Stratus
i assume you mean how to replace the back plate as i would,nt think any repair would be safe , strip out the brake parts including the brake cylinders , clamp the flexable brake line to stop fluid draining off , easier for the bleed of system when back together, the back plate is bolted to the stub axle remove the bolts , remove the plate , refit is the reverse
May 29, 2014 | Cars & Trucks
Husqvarna Chain saw 460 rancher chain brake problems
THERE LINKED TOGETHER SOUNDS LIKE, TAKE THE SIDE PLATE OFF THE SAW AND BLOW IT OUT WITH COMPRESSED AIR, THIS I THINK WILL SOLVE THE PROBLEM . IT'S JUST A GOOD IDEA TO BLOW OUT THE SAW AFTER EVERY USE .THINK SAFETY !1. JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Husqvarna Garden
Get side plate back on my husqvarna 350 chainsaw and tighten the 2 washers back on and the chainsaw cuts out. what could be the probelm?
It could be the brake has activated, the band is now smaller than the drum, as you tighten the nuts the band which is not properly over the drum is locking against the clutch, thus stalling the engine, you need to remove the cover and load the brake, there is a couple of ways to do this, you can remove the hand gaurd from the saw and use this to insert into the brake mechanism, then pull it firmly back until the brake clicks and the band locks back, or you can remove the clutch and drum, the brake will easily go back onto the saw, you can then load the brake on the saw in the normal way, to remove the clutch, there is two cut a ways in the clutch centre so as to insert a screw driver, you can then strike the head of the screw driver to jar the clutch off against the compression of the saw, it is a left hand thread.
Sep 17, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 435 chain saw I remove plate without releasing brake. How do I reset the brake.
Hi, grip the plate in a vise where the bar nuts tighten up to and pull the chainbrake lever until it clicks back, regards Phil.
Aug 27, 2011 | Garden
My handbrake engaged and would not release. I removed the cover plate and the can not get it back on. It appears the brake is still engaged. I have a e235 series.
If the brake is on then the band is now smaller than the clutch drum so will not go back on, you need to load the brake, to do this clamp the brake in a vice, be careful not to damage the cover, remove the hand guard from the saw, there is one torq screw on the starter side holding it on, once off engage it into the brake mechanism and firmly pull the hand guard back until the brake clicks and loads, now re fit the hand guard and the brake,
Aug 14, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
Replacing The Chain On my Husqvarma Chain Saw
Release the chain brake. Remove the clamping nuts on the cover and back off the chain adjustment CCW several turns. That should free the cover and allow the bar and chain to be free. Hope this helps!
Jun 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My chain on my husqvarna 435 x-torque power saw will not move
Well not exatly a 1999 Park Ave,but I will give it a try.We had several solo brand saws where the plastic parts got hot and melted causing the brake to come on.I could not find a parts breakdown of your saw but there has to be something that makes the brake come on.Part not in the rite place or something mis aligned.Try to get a parts brakdown and make sure that everything is where it is suposed to be.
Jan 18, 2010 | 1999 Buick Park Avenue
18" husqvarna chainsaw
It sounds like your chainbrake was on when you took off side cover .To get brake off place cover against saw with bar off so cover fits into brake lever and pull back on lever
Oct 14, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
13 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
