Question about Panasonic Toughbook 72 Notebook
Cf72 new fan not working
New cooling fan don't work from the motherboard don't know what turns it on but the fan needs to work system gets hot and lockup.
  • 70 Answers
You Better replace the fun before your system get spoilt..or replace the entire heat sink
Posted on Oct 16, 2013
Car gets hot pretty quick and will overheat, noticed fans arent coming on when car is hot or if I turn a/c on. Have caught them running recently but didnt catch it again.
it could be the cooling fan relays or possibly the cooling fans. to check the fans disconnect the plug at the fans and run jumper wires to them both power and ground. if they don`t work then the fans are bad. check voltage and grounds at the plugs when they should be running, if they are good then the wiring is good. it could also be the coolant sensor for the fans that send the signal from the sensor to the computer so it knows when to turn on the fans. the fan that runs with the A/C when turned on could be the A/C relay.
Sep 10, 2015 | 2003 Dodge Intrepid
My 2010 Chevrolet Aveo LT is making a clicking sound when I turn on my AC, but I turn it off it stops- occassionally blowing cool air but then turning hot. Any suggestion for an easy fix without breaking...
Your system is low on R134....the clicking is the compressor engaging and disengaging. You will get cool air while compressor is on, then warm when its off. They will act this way when R134 is low. Now either a leak in the system, or the system just needs a boost. Another thing to check is the condensor fan under the hood.When you turn the AC on,the condensor fan needs to be running, if its not then its a bad fan motor,relay, or fan sensor. I don;t know what your abilities are, but maybe armed with this info you can work on it yourself, or at least not get taken advantage of at the mechanics. Good luck !!
May 26, 2014 | 2010 Chevrolet Aveo 1.6
HOW HOT SPOTS ARE FORMED
Hot Spots? sounds like wrong motherboard drivers or not updated overuse of cpu by stuff running in the background, toolbars and the cooling system not working properly. maybe need some paste under cooling fan and on top of processor or GPU where fans are located.
Youtube can give you more info on how to fix things.
Oct 28, 2013 | Computers & Internet
Want to know why one fan turns on all the time but the other two don't. Is this normal. The heating is working fine besides this. Tax
That's a condenser fan motors they work when you a/c system is running. On hot weather temperature they should work all the motors to keep the system cool.On the winter time they never works cause the weather outside is too cold.
Feb 03, 2013 | Heating & Cooling
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
Where i can run cooling fan on hp pavilion dv6 laptop 2011 ? i buy new one but i don't no which button i have to press Please help me
It sounds like your cooling fan has stopped and you bought a new one.
The fans are plugged into the motherboard. Your motherboard probably has at least two fan connectors-they are marked "fan" or "case fan" or something like that. There is no button to turn them on. They come on when you start the system.
Jun 03, 2011 | Computers & Internet
Everytime my charger is plugged in, my laptop decides to turn off. It gets really hot underneath. Do you think i'll need a new fan?
Check the vents. Quite often it's a build up of dust on the fan and surrounding area.
Give it a good blow out and see if that helps
Feb 22, 2011 | Computers & Internet
Toshiba Sattelite a135-s2276 turn on fan working but no display
I think some cooling devices on your laptop stopped working which might have lead to Motherboard problem due to heating.
Jun 22, 2009 | Toshiba Satellite A135-S2276 Notebook
Power to the mobo
Without having the specs on the motherboard or knowing how old it is, it's difficult to say if it is beyond repair. Although my experience with computers shutting down that quickly while attempting to boot have been a problem related to processor overheating. Processors get very hot within seconds of powering on. If the processor cooling fan or the thermal paste is not working as intended the system will shut down quickly. You may want to check those two possibilities before purchasing a new motherboard.
Nov 19, 2008 | FIC AM 37 Motherboard
CF72
have had motherboards become static choked, and all you can do if this is the case is to leave it plugged in to power supply, but turned off, for a day or two. don't know if it works with laptops, but sure works great with "dead" motherboards.
Dec 10, 2007 | Panasonic Toughbook 72 Notebook
Panasonic Toughbook 72 Notebook Logo
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
