Question about Bissell 1697W Powersteamer Pro Upright Vacuum
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Posted on Oct 19, 2013
  • 3422 Answers
SOURCE: bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Posted on Jul 20, 2008
  • 29 Answers
SOURCE: Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
VacuumRepair
  • 438 Answers
SOURCE: i took my Bissell Powersteamer Powerbrush Deep
Here's a picture of the tubing on the PowerSteamer from an overhead view. I hope this helps you putting the machine back together. I know personally how challenging this repair can be, this picture really was my Bible when I was putting back together the machine for the first time. If you have a question about a particular tube, please feel free to add a comment to the repair page, and I'll be more then happy to answer any follow up question that you may have. If this was helpful to you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner. This is greatly appreciated.
Here's the picture for you:
Chris Jones
GoVacuum.com
Posted on Apr 15, 2010
  • 4 Answers
I have owned three Bissell cleaners and experienced clogged hoses each and every use. Do not put carpet cleaning solution in these machines. They are not designed correctly. If you have a tough spot, just use some liquid dishwasher detergent and a scrub brush. It will get almost anything out! Try it! Then, use the Bissell with hot water only to clean up any detergent residue.
Have a great day! Bissell Sucks!
Posted on Aug 31, 2010
My PowerSteamer PowerBrush Deep Cleaner 1694-W wont spray water
Well what I had to do was replace the pump motor you will have to take it apart and look to see if it has ant rust then look at the pump witch it is a white canister looking thing see if it ceased up and then use 3n1 oil or wd40 on it and work with it tell it is free spinning! Then it will work
May 03, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Cant get it to spry solution on to carpet hose pluged if so how d
It is because the pump belt is worn or stretched. Here is the replacement you need:
Bissell Proheat Pump Belt
May 19, 2010 | Bissell PowerSteamer Deep Cleaner Plum...
Powersteamer problems
You need to replace the pump belt. Here is the belt you need and it comes with printed instructions:
Bissell Pump Belt
Feb 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Wont **** up water
Go to bissell.com go unger frq.asked questions. Also check your belt
Jul 23, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Bissell 1697W Powersteamer Pro Upright Vacuum Logo
223 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
