Question about Microwave Ovens
Emerson mw8992sb The numerical keypad will not work. So I cannot set a specfic amount of cook time nor can I set the clock. The only way to use the microwave is to use the 30 second button. Can this be fixed?
  • 883 Answers
SOURCE: Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
Posted on May 25, 2007
SOURCE: Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Posted on Dec 11, 2007
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
SOURCE: My mother just bought an Emerson MW8119 Microwave
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Posted on Aug 18, 2009
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Posted on Jul 11, 2010
How do I set the clock on Emerson microwave model mwg9111sl
Hello!
Here is the link to the manual for Emerson MWG9111SL - setting the clock.
I hope it will help!
Microwave Cooking Emerson MWG9111SL 8 23
Jun 19, 2017 | Emerson Microwave Ovens
A time was set on the oven and it is the wrong time. i would like to change it.
Good afternoon Penny.
The manual for this microwave can be obtained/viewed here ( and have tips for all those other things like changing the scroll speed of the display )
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40536-1.pdf
If you go to to Page 24, the time set is a fairly common one:
  1. Press [Clock]
  2. Enter Time of Day with numeric keypad
  3. Press the [AM/PM/Scroll Speed] Button under the Zero key.
  4. Push [Clock] or [Start] to finish and set the time.
Cheers - hope this helps.
D
Dec 01, 2015 | GE Spacemaker JVM1740 1.7 cu. ft....
The keypad is acting crazy sometimes it will just beep for a long time. When it is done cooking the signal goes on and on and when you try to use it the keys don't always work or they beep for a prolonged...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes then try again.
Aug 11, 2013 | Emerson Microwave Ovens
Emerson microwave MW8992SB Just nothing. No clock no light. worked last night.Has electricity to it.
The main fuse has blown inside the microwave, the most common reasons are, one or more of the door switches is defective, the high voltage capacitor has shorted, or possibly the high voltage diode, and sometimes it just the fuse. I recommend a tv tech or appliance repairman because there are dangerous high voltage present.
Jan 17, 2011 | Emerson Microwave Ovens
None of the buttons are working; unplugged and
Depending on the model its down to the keypad
Feb 12, 2010 | Panasonic Microwave Ovens
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
Broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Emerson MW8987B/W Microwave Oven
Keypad Problem?
May 25, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
