Question about NEC 250GB 7200RPM Serial-ATA 1.5Gbps 3.5-inch Internal Hard Drive
SerialATA-1.5Gbps eSATA-3Gbps USB 2.0 not detecting my computer
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
Drive is only detected by XP when USB connected. It is detected by the Steelvine manager with either USB or eSATA.
1. Plug it in.
2. Right click on "my computer"
3. Click "manage"
4. Click on "device manager"
5. Right click on your computer's name
6. Click scan for hardware changes.
May 10, 2011 | Sans Digital MS2UTN+B mobilestor 2...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My hard drive doesn't show up
If the external hard drive is not detected by yur computer, try first connecting the drive on a different USB port so we can test the USB port and then after that if still not yet detected try a different USB cable to test the cable and after that still not detected connect the drive on different computer so we can see if this is already a hardware problem.....
Jan 05, 2010 | Sabrent eSATA External Drive Case
Seagate 50gb external drive - not recog on computer
It could be your USB or firewire. i had a problem with my h drive and now i'm using a ps3 usb cable instead
Sep 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB Not detecting
First check if other usb data drive like is pen drive is getting detected. Check all the usb ports. Check the Seagate drive with other computer if you have.Restart the system in safe mode and check.Try to create new admin account and check .If also chck the usb cable to make user it is not defective. If nothing works probably your hdd is gone bad. Good luck.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have seagate 500gb hard disk which is not recognised by win xp what should i do
If using USB try it on another USB port, if on eSATA then try using USB to see if it will detect it via usb
Have you got another computer you can try it one just to ensure that the hdd is actually working ?
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Device driver problem in Windows XP using a USB 2.0 device on a laptop with USB 1.1 controllers
Disable the USB 1.1 on-board option from the motherboard and install a 2 or 4 port USB 2.0 PCI/ISA card.
These cards are quite cheap these days and will do the trick rather than replacing the more expensive back up external hard drive ESATA/USB 2.0 hard drive.
Apr 14, 2009 | Computers & Internet
Seagate pro 750, xp, xfx 630i mother board, esata
those drivers should be on seagate site, by o/s...make sure you have latest(not what came with disk, by the way)
check your computers warranty here 4 FREE
Mar 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
NEC 250GB 7200RPM Serial-ATA 1.5Gbps 3.5-inch Internal Hard Drive Logo
116 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
