Scangear error code 3 206 0 - Office Equipment & Supplies
Code 2,250,200
Re: Error code 2250,2 or 2155,33 on scanner 9000f - Canon ...
community.usa.canon.com/t5/Printer.../Error-code-2...2.../123789
Nov 6, 2014 - Dear all Canon staff, I brought my 2 years ago. And I had not used it for around 1 year. When I used it again, Scangear run out error code 2,...
Sep 05, 2015 | Office Equipment & Supplies
My printer is canon pixma mp 140, scan is no working. code 21140 displayed what can i do ?
I bought a Canon PRIXMA MP 140 about a year ago, but now it doesnt work because when I want to scan the ScanGear box comes up with this error:
Printer maintenance in progress, scan after it is complete
code 2,114,0
May 27, 2010 | Canon PIXMA MP150 All-In-One InkJet...
ScanGear Internal Error Code:5,202,54
all i am getting is advertisements that can "fix" my computer at a price, everywhere says there is a driver out of date but nowhere tells u how to fix it
its a cannon mp250 throwing up error5,202,54 when trying to scan
Mar 07, 2010 | Canon Office Equipment & Supplies
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Scangear Error
i think this problem come with windows xp update!
when u started to see this messege?
Nov 30, 2008 | Canon MP610 Photo All-In-One Printer
Canoscan 4400F & Vista
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Oct 19, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
1,034 people viewed this question
k24674
jasbo
jasbo
