Question about Video Game Consoles & Games
Genesis Hausmeister not sucking properly - Video Game Consoles & Games
Installing hub cap on 2009 genesis
Use a rubber mallet and make sure the hub cap is totally flush against the wheel lip. Be very careful and take your time.
Jun 30, 2016 | 2009 Hyundai Genesis
Genesis hausmeister
Maybe Genesis could be persuaded to send the correct video to help you figure this out.
Jan 18, 2014 | Video Game Consoles & Games
I have an old sega genesis and got new plugs to plug it into my 42'' HDMI Vizio. all the plugs are in and the light is on but the screen stays blank. I have tried blowing on the game and got the...
Did you say HDMI? I don't think there are HDMI plugs for Sega Genesis. You can plug in your Sega via composite video through RCA cables (yellow, red white) or via RF signal through coaxial cable. Check your TV's specs to make sure it can display standard definition content via composite or via RF.
You can double check to make sure your Sega Genesis is working properly by plugging it into an old-fashioned CRT (fat tube) television set.
Sep 02, 2011 | Sega Genesis Console
Wont come on
Man I haven't seen an actual Sega Genesis console in years. Anyways...
1) Make sure that everything is plugged into your system properly. 2) Check you make sure your TV is on the right channel 3) Check to make sure the fan is at least powering up when you turn on the Genesis. If it is then the Genesis is working. 4) Plug something else into the TV to make sure it works.
Remember, HDTVs and LCDs and this whole Al Gore's Gone Green thing wasn't around when they made the Sega Genesis, so conventional means to playing a Sega aren't your best option. Don't plug it into the wall either, make sure you are plugging it into a surge protector.
Hope this helps.
Jan 01, 2011 | Sega Genesis Console
When i plug in my sega genesis the light is on but no video do you know whats wrong with it?
Double check to see if your RFU or A/C Adapters are properly connected. Also, if it is an RFU adapter, make sure the Channel on your TV matches the Channel on the adapter.
Jun 19, 2010 | Sega Genesis Console
I plug in my sega genesis and no light came on.
First check the AC Adapter, if it is properly connected to the main socket. check for blown fuses and replace if found any. HOPE THIS WILL HWELP
May 30, 2010 | Sega Genesis Console
Video Game Consoles & Games Logo
13 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
