Question about Sennheiser HDR 130 Consumer Headphones
RS 130 surround light is flashing and unit is not transmitting sound
2 Suggested Answers
SOURCE: Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Posted on Jan 21, 2008
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
2. Press the CHECK button on the remote controller
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Surround sound tv
To help you better, you need to provide the make and model of your surround sound system and your satellite TV box..
Nov 28, 2013 | Philips Magnavox MRD500VR System
There are no audio outputs on my 37 lcd only four audio inputs. How do I connect my surround sound system.
look for an optical or "coax" digital audio connect jack. That will transmit all surround sound channels on a single cable. That will go from your TV to your surround sound "receiver's 'digital audio in'
Also - if you are using HDMI the sounds goes over that cable along with the video.
Oct 16, 2013 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Surround sound does not work
If there are any power cords from other components near speaker wires the electric interference transmits through speaker wire causing a buzz.
Aug 20, 2009 | Denon AVR688
No suround when watching tv with sky + box,
You will need a DVD player with an optical output, as the sky engineer said. A Co-axial S/PDIF output could also work if your surround sound has that input, however not all units transmit surround encoded sound through the Co-Axial output. Only option really is to upgrade if that doesn't work
Mar 05, 2009 | Televison & Video
RS 130 not working?
I am having the same problem...i tried resetting it as well...no luck
Jan 13, 2008 | Sennheiser RS130 Headset
Jan 10, 2008 | Sennheiser HDR 130 Consumer Headphones
Sennheiser HDR 130 Consumer Headphones Logo
43 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
