Question about Dishwashers
Electrolux ESL 63010 has no power
Electrolux ESL63010,this machine has no power,I have replaced the fuse and checked the main circuit board,where do I go next?
  • 409 Answers
SOURCE: ESL 63010 will not start program
does your dishwasher have a timer button on it? sounds like the switch behind the button needs to be replaced.
Posted on Sep 13, 2008
  • 423 Answers
SOURCE: Door will not stay down while loading
Please search for the sticker that is probably one the door (right side) that lists the model and serial number of your dishwasher. It is hard to provide specifics without this information.
But generally, the spring that is part of your door hinge has broken and will need to be replaced.
Please post back here with more info, OK?
Posted on May 05, 2009
  • 17 Answers
SOURCE: there is power to the main circuit control board, but no power exiting. unit will not run. no power to display.
There is a possibility that it could be a thermal fuse located in series with the hot side wire. If you are able to find it, and own an ohm meter, find out if it is open.
Posted on May 18, 2009
SOURCE: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Posted on Jan 10, 2010
SOURCE: Hotpoint dishwasher BF1620 blew the main fuse
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Posted on Feb 07, 2010
NO POWER IN MACHINE .POWER AT SOCKET
Possible that the power supply to the main board has failed. You need to remove the control panel to get access to this section.
Remove the panel and check mains power into the board and power supply, check for burnt surge protector which could have burnt the fuse. Also a short in the circuit could have done the same, if not the board must be replaced.
Apr 11, 2013 | Electrolux Washing Machines
Program lights not showing on front loader electrolux jet system XL 8 kg
You most likely have had the main control board blow on your Electrolux washing machine.
It is quite common for the main boards to blow on these machines. The main board is located on top of the machine towards the front right hand corner.
You need to remove the top panel via two screws on the back. Then slide and lift to remove top cover.
You will notice a white plastic casing fitted on the right hand side towards the front. This plastic cover holds the main PCB and is vertically fitted on a cross beam and has many wires going into it.
Get a quote for the part as they are expensive. Best to get a qualified repairer if you are going to replace this part, as there may be a problem elsewhere in your machine, causing the board to blow.
Electrical storms and power-surges also cause the boards to blow. Other time an electical short circuit or leaking water on electical components can cause this. Another item to watch out for are cocroaches. They can nest in the boards and short things out.
Ash
Sep 18, 2011 | Electrolux Washing Machines
What does the shower and bar smybol mean on my ESL 63010 Dishwasher please?
I've been dealing w/electrolux for over 2 years on a dishwasher problem. Technician have tried all that they know & the dishes still come out dirtier than when they go in. I've been using it as a drying rack. Kinda exspesive drying rack. Electrolux won't stand behind their product either.They are offering me a 60% discount on a new Elextrolux dishwasher! Are they kidding?
Apr 01, 2011 | Electrolux Dishwashers
Dec 17, 2009 | Dishwashers
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Sep 13, 2008 | Dishwashers
Electrolux EL7020A Oxygen 3 dead!
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
Jul 08, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Oxygen 3 will not turn on
This is often caused by a failure of a fuse on the Sumo board, or occasionally by a failure of the cord reel. I just posted a rather extensive set of instructions on how to check these things as a response to a different thread, but I will repost them here:
-R
Dec 31, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
