Question about Canon Cameras
Camera power not working - Canon Cameras
    Problem Solver:
  • 15 Answers
It is proberbaly because the batterys are out because batterys dont last for ever even rechargable batterys only last for 2-3 years it is best to buy a new camera if it is not the batterys causing the trouble and by the way if you are buying a new camera buy a sony the repairs personnel can easily sort any probs when you get any
Posted on Apr 24, 2009
In my 4 camera surveillance system two cameras stopped working
The screen should say a message similar to "VIDEO LOSS" if it does The power packs or multi power supply to your cameras are easiest to check for starters. Unplug the power to a working camera and plug it into the non working camera close to the dvr. If the camera that didn't work came on, then the power pack is most likely the problem. If it didn't have a message saying "VIDEO LOSS" then it may be the sensor that switches to day/night vision. I have had cameras that when it switches to night vision the screen goes black and unplugging in the power to the camera and re-plugging it in gives it a boost and then comes on. If switching the power from a working to non working camera don't work get the ladder out and unplug and re plug in the connectors at the camera in case it is a connection there. Last if that didn't work would be to take the camera that don't work off and plug it into the end cables to a working camera, if it works then I would suspect the cable to the camera to be bad. Just a process of elimination.
Nov 29, 2014 | Sony 1/3 Sony Super HAD CCD Outdoor IR...
Nikon L22 camera will not power with new batteries
I would see if the camera works with disposable batteries. If it does, your battery charging circuit may be faulty. Are you charging the batteries in the camera or in an external charger? If it's in the camera, buy an inexpensive external charger and see if that works. If you eliminate the charger as the cause, the camera will probably need to go in for repair. Contact the Nikon Repair Depot listed in your camera's manual or on the Nikon USA website. They can give you a repair estimate.
Nov 28, 2012 | Nikon Coolpix L22 Digital Camera
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
I own a Sony DCR-HC47E Handycam.It will not turn on
i have a problem with my sony dcr-sr47 camcorder it wont charge the battery camera works fine with power supply any solutions.
Dec 15, 2009 | Sony DCR-SR47 Camcorder
Camera works but no LED display and power switch not working. battery has been tested and is ok.
First you, should give the model of the camera, which will help for better understanding the problem.
Aug 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My Canon sd 1000 won't power on. Battery is OK.
Check to make sure the batteries you are using have enough strength and volt power, if not it wont work. If they are really cheap, and last only a weak in the remote, they wont power up a camera.
Jan 21, 2009 | Canon PowerShot S1 IS Digital Camera
Camera won't turn on
I am assuming that the power does not go on or it immediately turns off as it is turned on.
Try the docking station or the 3.3 AC adapter to the camera. Plug that in to live power. If you hear the lens motor (by default the lens is retracted to closed position when plugged to AC power), then the camera is operational. If not, there is power failure with the camera.
If the lens motor work, then try to turn the camera while plugged to AC power. If it turns on, then there is something wrong with the battery or with the chamber. If the camera does not turn on, then check the button board for a bad power switch.
Check the LCD closely under a bright light when you do this test. You may see a faint a flash of display that disappears. I have not figured out what causes this. This would mean that camera power supply is working but nothing is telling for the camera to stay on.
Aug 02, 2008 | HP Photosmart M407 Digital Camera
Powering off
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
Jun 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Error message saying video lost and not recording
There are several possible issues at play whenever the lost video message appears.
First, have cameras lost power? If you powered cameras through a central power source, inspect it and verify it is working
If you powered cameras through a plug in transformer, touch it, if warm it is working
Next touch the cameras, are they warm? If so, they have power.
Once you have determined cameras have power, disconnect power for several minutes. Turn power back on, if cameras respond and send video, your cameras have likely suffered damage from a power surge and are near failure.
If you have access to a small tv with an RCA video in jack, you
can test this by leaving the camera powered, run a short length of cable from the tv to the camera. We use hand held mini monitors to test this, but they are pricey,
It is most likely that have power surge damage and the cameras need to be replaced
Oct 25, 2007 | Geovision GV-650 BNC (GV6504) Video...
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
Cameras Logo
195 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
