Question about Acer ICONIA TABLET A501 10.1" NVIDIA TEGRA250 DUAL CORE 1GB 32GB ANDROID 3
Acer a501 dead android robot red triangle - Acer ICONIA TABLET A501 10.1" NVIDIA TEGRA250 DUAL CORE 1GB 32GB ANDROID 3
How do i unlock my nexus 7 when its on the screen with android robot laying on its back?
Android robot laying down with a red triangle having an ...
https://androidforums.com > Forums > Featured Forums > Android Lounge
Mar 24, 2013 - 14 posts - ‎7 authors
Whenever i try to turn my android tablet on it displays android robot laying ... an exclaimation mark in a red triangle and dont let me proceed to its desktop . ... and holding it until it turns off and then turn it back on can revive it, ... no command error ' Android Forums
19 Jun 2014
HELP-Tried Recovery Reboot, Red Triangle w ...
15 Jan 2012
More results from androidforums.com
SOLVED: android guy on his back - Nabi Jr - iFixit
https://www.ifixit.com/Answers/View/349279/android+guy+on+his+back Oct 31, 2016 - my android guy on the screen is laying on his back with the stomache door ... Android recovery mode" and a few seconds later an Android robot ...
How to Fix The Dead Android and Red Triangle Error Symbol - YouTube
? 1:44
https://www.youtube.com/watch?v=58EPvbwPbe0
Oct 5, 2016 - Uploaded by Gauging Gadgets
Meaning of Green Android laying down and a red triangle with an exclamation point inside it: •If there is ... All ...
How to Fix The Dead Android and Red Triangle Error Symbol Android Recovery...
Jul 07, 2017 | Tablets & eReaders
Trying to factory reset proscan plt7810k but comes to android robot with red triangle
If you have rooted your tablet you will have to unroot it for it to update
Jan 20, 2017 | Tablets & eReaders
Can u reset ipad if android robot laying down with triagle above it
iPads don't run Android, they run iOS!
you have some lesser version of a tablet, but here is the Android information you are looking for.
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Jan 17, 2016 | Tablets & eReaders
I bought the tablet off of face book yard sale and
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
or try this link out.
android man on his back with red triangle on his chest Google Search
Dec 15, 2017 | Tablets & eReaders
Acer iconia a700 tablet
Hi there if you follow this link http://www.acertabletforum.com/forum/rescue-squad-guides/5168-how-perform-factory-reset.html It will walk you through the reset process :)
Jan 26, 2014 | Tablets & eReaders
Zeepad does not open
can't get netflex to show picture.
Dec 29, 2013 | ZEEPAD VIA8650 Android 2.3 Tablet
My tablet comes on but has a green monster with a red triangle and it wont let my tablet get pass it
Hi.
There is corrupt data on the Proscan 7.
First of all if you have an SD card in the slot remove it and turn the Android on to see if it boots. If i does then you didn't have it inserted properly or its corrupt.
If is still shows a Android laying down then follow the procedure below.
1. IF YOUR TABLET IS ON, POWER IT OFF. 2. PRESS AND HOLD POWER UNTIL THE DEVICE POWERS ON, THEN IMMEDIATELY PRESS AND HOLD VOLUME DOWN (WHILE STILL PRESSING POWER). YOU WILL SEE THE WORD START WITH AN ARROW DRAWN AROUND IT.
3. PRESS VOLUME DOWN TWICE TO DESIGNATE RECOVERY MODE.
4. PRESS POWER TO RESTART INTO RECOVERY MODE. YOU WILL SEE AN IMAGE OF AN ANDROID ROBOT WITH A RED EXCLAMATION MARK.
5. WHILE HOLDING DOWN POWER, PRESS VOLUME UP.
6. USE THE VOLUME KEYS TO SCROLL TO "WIPE DATA/FACTORY RESET" AND PRESS POWER TO SELECT IT. 7. SCROLL DOWN TO "YES - ERASE ALL USER DATA" AND PRESS POWER TO SELECT IT.
Regards.
Jul 15, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Acer ICONIA TABLET A501 10.1" NVIDIA TEGRA250 DUAL CORE 1GB 32GB ANDROID 3 Logo
114 people viewed this question
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
