Question about Samsung Office Equipment & Supplies
I do not see how to send a Fax. I can make a
I just bought a used Samsung FX 1505 personal fax but I can not figure out how to send a Fax. I can make a photocopy but do not see the ''send'' button. Thanks.
  • 186 Answers
Make sure you have the phone line plugged in, insert the document dial the fax number and push START.
Posted on Apr 25, 2009
Hp 8500 printer/fax machine will no longer receive a fax in color but can send in color. it used to work fine both ways. What can I do to fix the problem?
If the person who is sending the fax cant send in color, then you would not be able to receive the fax in color. Just make sure you choice the option to received the fax in color. Ask someone to send you a fax in color and just received in color.
Feb 17, 2013 | HP 8500 Premier All-In-One InkJet Printer
Everytime I send a fax from my samsung sf 370 i get
It can be the other person's fax or there is something wrong with your lines. Conect fax to another line then try again.
Oct 01, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
Fax sent is received in blank
Here is a possiable problem you got the paper in the wroung way or your lamp is not working check both~)
Jun 22, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
Samsung SF 3200
The person you are sending to has a busy phone line.
Call your cell phone from the fax machine to test.
Oct 24, 2008 | Samsung SF-3200 Fax
Fax can't be received by one outside fax machine (a Brother Intellifax2800).
Your Samsung unit incorporates a Super G3 fax algorithm completely compatible with all similar machines. Please the other person to have his phone line checked, for the machines do not choose when or where to fax.
Sep 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Call Sevice 4
reset the unit..press menu#9000*550 Then press start.Call service 3 has something to do with the temperature of the unit check thermostat @ the fuser unit.replace it because the thermostat is not switching to on/off condition although it reaches its peak temperature.
Mar 17, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
When I send faxes the reciever gets a different fax caller ID
Ring 13 2600. Tell them you bought it (NOT SECOND HAND) and you lost the manual, Explain the problem and they should give you an answer for free!
Jan 28, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
109 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
