Samsung ps aw710 - Audio Players & Recorders
I want samsung sorround sound woofar modelle ps-wtx500
http://www.ebay.com/itm/Samsung-PS-WTX72-Passive-170W-Subwoofer-for-Home-Theater-System-HT-TX72-8A-/171407571535?pt=Speakers_Subwoofers&hash=item27e8affa4f
Dec 17, 2014 | Samsung Televison & Video
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
Reparing Samsung PS-50 C430 Plasma TV
Good day.
If you can identify those shorted transistors and you can remove them, you can actually order them from Samsung through this links http://electronicsmarket.com.au. It has everything Samsung, you will not be disappointed. Click on the link, click on Plasma TV's, then click on PS50C430, then (again) click on the version you may have and a list of possible parts will appear for this model. I didn't go through the long list (5 pages), but I believe what you're looking for is there. If not, you can contact them Website and ask not only for the transistors but you can actually get further help with your query.
Hope it helps. Cheers
Jul 06, 2014 | Samsung "PS-50C430 50"" 720p Multi-System...
Samsung ah59-02131f remot amd how it works on a samsung tv ps bn64-00818a
Most Samsung remotes work with other Samsung TV sets. Simply, test it
Jul 05, 2014 | Samsung AH5902131F Remote Control
How do I fix my Plasma TV ?
Not sure it is a transistor. May be bad caps in fisrs or secondary power supply. contact mfg of transitors to see if yours is transferable.
Jul 04, 2014 | Samsung PS-50C430 MULTI SYSTEM PLASMA 50"...
I have a Samsung ps-wx30 surround sound system and I don't know how to connect it to my tv
Couldn't find PS WX-30 on the net or Samsung's site. Could you please confirm the model no.?
Jun 01, 2014 | Yamaha RX-V463 Receiver
PS 7200 SYNC WITH SAMSUNG S4 PHONE
Hello. When you pairing a blue tooth with a samsung if required a code it would be 0000 unless is a specific code by the manufacturer.
Fix: turn off the blue tooth on settings on the phone and turn it on. Let the phone scan for devices, if it says found p that should it. When you see it on the phone press on it, the phone and Bluetooth should pair by doing so. I hope this helps. Good luck.
Mar 04, 2014 | Samsung GALAXY S4
Where is back slash on samsung keyboard ps/2
On a Pleomax PS/2 keyboard it is right above the Shift key, next to the Enter key.
Jan 20, 2014 | Samsung BASIC PS/2 KEYBOARD
90 people viewed this question
 Grubhead
Grubhead
