Question about HP Officejet 6310 All-In-One InkJet Printer
Printer is not printing.
My officejet usually works fine. Somehow, it is not prinitng out any documents. I tested it to see if it would still copy a document and it did.
What is wrong? How do I fix it?
  • 495 Answers
Try these basic steps:
1) Restart your printer
2) Re-install printer driver again.
Posted on Apr 24, 2009
HP Officejet 5610 All-In-One. cartridge error: refer to device documentation to troubleshoot ... I was in the process of of printing a series of documents. does not print prpoperly
Will it color copy- stand alone? Try making a copy on the printer by itself. If the copy is still printing in blue, then go to the service section in the menus, and clean the print head, if that does not work then try the recalibrate function. -If the copy comes out fine when you try it stand alone, try deleting the printer and reinstalling the printer.
Mar 28, 2014 | HP Officejet 5610 All-In-One InkJet...
I have an HP officejet 4215 printer. I cannot get the cartridge (color) 57 to print color! It has been working fine with the smaller cartridge but due to high level of printing, I was told to get 57. I...
If all the the computers connected to this printer via network:
  • Shut them all down except for one.
  • Go to that computer and go to your printer and fax settings
  • Identify the Hp OfficeJet 4515 and right click on the icon and select properties
  • On the General Tab, click on the button that says, "Printing Preferences"
  • Select the "Features" tab and go down to Color Options and check to see that the radial button is green for Print in Color option
  • Underneath that, there is another setting thatsays, "Color Management".
  • Check to see that it is already selected with, "ColorSmart/sRGB or Adobe/rgb
  • Click Ok and return to the Properties
  • Go to Color Management Tab and check to see that it is set to Automatic.
  • Underneath that, you'll see "Color Profiles currently associated with this printer.
  • Look to see that the field is populated, if not click on ADD, and select each color profile that is available
  • Click apply, then OK
  • Shutdown Computer
Turn the printer off, unplug the power from it, wait a couple of minutes, then plug power back to printer, then power it up.
  • Restart the computer you were working with
  • Go to printers and fax options window
  • Select the HP OfficeJet 4515
  • Right click, select properties
  • On General tab, click on, Print Test Page
  • Go to printer to see if printing test page
  • Check to if the Microsoft Windows logo was printed in color
If it is in color, then print the color document you were previously attempting in color.
If it does not print in color, you will have to check your settings on the program that is being used for the document.
Jun 02, 2011 | HP Officejet 4215 All-in-One Color Photo...
Can't scan
please disconnect the power cable from the wall outlay and press and hold the power bottoum for 20-30 sec then restart .
try and make a copy from the printer
again try to print a test page from the printer and see how it prints if it prints fine then it should scan
if it does not print the test page fine then there is a problem with the printer itself
click on the URL to print the test page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01607730&cc=us&lc=en&dlc=en&product=3441026
follow the above mentioned steps
still if does not work try this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01124259&cc=us&lc=en&dlc=en&product=3441026
again try the first step
and after that contact HP let them know what have you tried so far and they would probably replace the printer for you idf the issue is not resolved
HP TOLLFREE NUMBER -1800-474-6836
if the printer is in warranty they should replace
Thanks
Regards
Hamid.
Feb 23, 2010 | HP J3680 Officejet All In One Printer
Incomplete document printing from computer
try to reinstall the driver of your printer and run it again. If it doesn't work then re configure it.
Jun 16, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP All-in-One Printer Series 1300 prints blank copies
Have you tried printing a test page from the printer itself. usually holding down the power button will instruct the printer to print a self test by itself.
Mar 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
New Hp Officejet 5610 All-in-one - Printing?
You may have a couple of problems. First, you say you have more than one icon in your Printers dialog box for 5600 series printers. My guess is that you installed two different drivers, one for the 5600 and one for the 5610.
Try deleting the 5600 printer icon and making the 5610 the default printer. Run the test print again to verify it works, then open a Word document and see if you can print that.
This brings me to the second issue; what exactly are you trying to print? The issue in this case, may not be the printer but an issue with the document. Some documents have a security feature that prevents printing. Try different documents (Word, Excel, etc...) and see if the problem is across the board. Post the results here.
Thanks.
Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
My Hewlett Packard OfficeJet 500 was faxed a 45 page document, which I accepted (by activating the "Auto Answer" button) and printed. Then, while I was briefly out of the room, a second copy of...
I went back to Control Panel, and, following a hunch, found my way to discovering that the printer had somehow gone into "Pause" mode. I then simply clicked on the word, "Pause" and it converted to "Active."
Aug 15, 2008 | Office Equipment & Supplies
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
