Question about EdgeStar Portable Air Conditioner Heater
Do I need to keep the hose connected to the window in winter time while I use the heater.
    Scholar:
  • 64 Answers
The hose is only needed to pump out hot air while using the AC features and not needed at all for heater functions.
Posted on Oct 15, 2013
How do you winterize a 2015 chaparral 390 QSMB?
At the back of the water heater ( unless you have a bypass outside in the compartment with the sewer and city water )there should be 3 valves, the one on the vertical line leave open and close the 2 leading into the heater. That will bypass your heater. Then connect your antifreeze hose (garden hose ) to the city connect. Using a water pump ( just like the one in your unit) have someone plug it in ( suction hose in the antifreeze of course) open one at a time each faucet hot and then cold till you see the pink running. It may take a couple gallons so get a 5 gal jug. Don't forget to remove the water filter under the sink.
Oct 19, 2017 | RVs
Tip
How to diagnose ALL vehicle NO heat problems
It is winter and you jump in your car start it up and turn the heater blower fan on.
You sit and wait...and wait.... NO HEAT !
Here are a few easy steps to help diagnose the problem:
1) After vehicle is completely warmed up, open your vehicles hood.
2) Grab a pair of gloves. Put them on, now put your hand with your glove on, on the TOP radiator hose. ( The top black radiator hose is the largest hose on the top of the radiator inlet running to the thermostat housing, in most vehicles)
3) Be careful NOT to touch ANY part of the engines cooling fan(s). Is the radiator hose HOT or COLD to the touch ?
If the hose is cold the easiest repair is to replace the thermostat. The thermostat helps regulate the engine temperature keeping it approximately 195 degrees Fahrenheit, and helps supply hot coolant to run through your vehicles heater core to keep you warm in the winter.
on Feb 09, 2010 | Chevrolet Impala Cars & Trucks
How do I disconnect heater for 2004 Toyota Highlander?
bypass the heater core. 2 small hoses run from the firewall to different locations on the engine (one should be the thermostat housing. dissconnect one hose from fire wall end, and reconnect it to where the opposite end of the other hose is located, creating a loop that does not include the heater core. The remaining hose (one end still attached to the heater core at the fire wall) should be connected to the opposite connection at the fire wall so it can be re-engaged next winter.
Actual problem seems to be the heat damper valve, which restricts water flow into the heater core, easiest fix is reattach the actuating cable to the valve arm (if this was detached) most costly is replace valve assemble/heater core assembly....
Oct 04, 2014 | 2004 Toyota Highlander
KeystoneVR1frontkitchenhow to winterize?Can I do it without an aircompressor
yes drain freshwater tank then remove intake of the water pump you will need a hose with a connector to connect to inlet of water pump then hook hose to antifreeze bottle then turn on water pump open faucets 1 at a time till you see antifreeze on each then pour some down the drains make sure to shut of inlet to heater and open bypass before turning on pump or you will fill hot water tank after all done return heater bypass to operation position
Oct 20, 2013 | Keystone 2012 Cougar 324RLB
My antifreeze is leaking and I am trying to find the leak. It also leaks from inside of my truck on the passenger side where their feet are.
Your heater core is leaking. Replacement of this part is a big job and should be done by a professional.
Jan 12, 2013 | Cars & Trucks
I am not getting good heat when heater is on, windows take a long time to defrost in winter and rear defroster also takes a long time to defrost rear window.
check radiator -thermosate-hoses -heater core far as the rear defrost window it works off of voltage maybe have somebody to look at this for you
Nov 01, 2010 | 2003 Nissan Altima
Can i bypass the heater core?
Yes. You would need to join both hoses from the firewall into a loop to circulate the water back into the engine. You will need to measure the hose sizes and make a connector. You will need to clamp the hoses to the connector.
If you use copper tubing, you should flare the ends to insure a good seal.
May 09, 2010 | 1995 Ford Escort
Front heat does not heat..but the back heat does..
your vacuum hose to the mixing valve is likely disconected
Nov 01, 2009 | 1999 Ford Expedition
Pipe that comes out of thermostat and goes into firewall is leaking coolent in '02 Impala, 3.4 liter? Whats this pipe? and can i use pipe dope or something?
This sounds like it goes to your heater core. It is like a small radiator inside your car that circulates hot engine coolant to give you heat when you turn on your heater. You should have rubber hoses that connect the heater core to the thermostat housing. Look closely as to what is leaking, the rubber hose, or the thermostat housing, and try to "snug" up the hose clamp if you can. Some time the thermostat housings corrode and leak. You will need to replace it if that's the case.(Keep in mide that some vehicles use clamps that are spring type, and you can't snug them up)
Sep 14, 2009 | 2002 Chevrolet Impala
EdgeStar Portable Air Conditioner Heater Logo
65 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
