Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Water Leaking all over from Whirlpool Gold Refrigerator
My refrigerator seems to be holding temperature fine, but recently things inside have become wet and there is always water either on the bottom of one of the shelves or on the refrigerator floor. The water will sometimes freeze into ice and I will spill over the fridge bottom and out the fridge onto my kitchen floor. I've looked under the fridge and the trays are dry under there (and dusty). I've checked to see if something is blocking the vents in the freezer (nothing is) and also turned the temp down under the recommended setting and it's still a consistent problem. I looked in the book but it's no help and I'm not even sure where to start. Please help! Thanks.
  • benham May 11, 2010
    is this a side by side or is the freezer on top and refrigerator on the bottom?
    Problem Solver:
  • 15 Answers
I think that the seals are ruined when the seals are ruined the water will leak outside and inside beacause all of the heat from outside will gather together and will melt the ice and will make the moisture act up and boost the process of it turning to gas matter into liquid matter.
Posted on Apr 24, 2009
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool ET1FTKXK Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge side cant keep 100 percent cold
Have you noticed a big difference lately in the cooling of the cold food section? Any time you open doors to a refrigerator or freezer you allow them to exchange room temperatures with inside ambient temperatures. The only time you should be concerned is when these temperatures begin to remain abnormally high. Many times the temperature rises in the kitchen while diner is prepared. Those temperatures also affect how long your refrigerator need to run to maintain the temperature settings you select. Your refrigerator has something called an Adaptive Defrost Control. If you should have problems with it you would notice a big difference.Another thing that can help is to make sure the condenser coils below refrigerator remain clean and clear of dust. The warm air circulating below your refrigerator is as important as the cold air inside. As for the vents that lead from freezer to cold food section they sometime become obstructed especially if they have a damper inside and frost locks the damper shut. If I missed something here please let me know, Thank You, Sea Breeze
May 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
469 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
