Question about Dewalt DW744XP 240V Heavy Duty Electronic Portable Table Saw
Wiring the interruptor to the motor of a DeWalt DW744XP-QS Type2
Hola tengo problems con mi SUV Suzuki XL7 2009 cuando la conpre medijieron k traiba el problema en el stiwch de la have I aora no ASE Nada no estarea
Por el a?o del auto pareciere desgaste de los contactos del interruptor de arranque o desgaste excesivo de la llave.
Antes de cambio del interruptor de arranque hay que descartar otrrasd posibilidades a saber: revision de fusibles y de los relevadores ( relays). Si alguno esta fundido, cambiarlo,caso contrario, el siguiente paso seria probar el motor de arranque en directo.Si no son los fusibles o relevadores y en directo arrancatodo apuntaria a un cambio del interruptor de arranque.Conviene que estas pruebas las haga un mecanico
Mar 02, 2017 | Suzuki XL7 Cars & Trucks
My battery powered dewalt jigsaw had lost power, it's not the battery as it works fine in my other dewalt tools and the brushes look pretty good to?
If the battery is good, and you feel the brushes are good, then the problem is either the motor or wiring. Either way, you will need a repair service to fix it. Here is how to find a service center near you: http://www.dewalt.com/find-service-center.aspx
May 20, 2015 | Dewalt Drills
Dewalt drill melts battery
There may be a short in the motor or wiring, or the gearbox is broken or otherwise seized up. Dewalt provides replacements for most parts at reasonable prices, so it's worth taking the drill apart to find out what is going on. I suspect you will find damaged wiring inside due to overheating; you may be able to identify the problem by seeing where the wire insulation is charred or melted. Unless you have a good drill of the same model so you can compare electrical resistance, it's a bit hard to ID a bad motor with an ohmmeter. However, you can try visual and olfactory inspection - if it looks and smells burned, it probably is. You still should check the transmission to make sure it isn't the source of the problem. DEWALT com
Jul 15, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Regulator outlet pressure too high ondd55146 type2
The pressure switch needs it's cut off pressure adjusted.
Feb 23, 2013 | Air Tools & Compressors
DeWalt DW708 switch
http://c.searspartsdirect.com/lis_png/PLDM/P0201024-00003.png
This is the newer 744 series, white cord to white motor and black cord wire to black motor.
If your motor needs the mag starter that 5th loose wire, usually red, goes to the start terminal on the mag starter.
Feb 14, 2012 | Dewalt DW744S 10" Portable Table Saw with...
It has been intermittent for a while now like there was a loose connection somewhere. But the other day the battery started smoking so I had to remove it. It is around 3 years old
Take a look at this diagram. Items 14 and 15 are the wires that run from the switch to the motor. They tend to get hot and melt the insulation of the wire where the connector plugs into the motor. If the bare wire touches the metal motor housing then it will short out. I would guess that is what happened.
http://servicenet.dewalt.com/Products/Detail/DC925KA#pp-parts
Jul 25, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Can i use parts from dw744 .qs from usa in norway . usa have 110v and we have 220v
I would have to think it would depend on what parts you are talking about. You can try and go to Dewaltservicenet.com to check compatability on the 2 items.
Aug 08, 2010 | Dewalt DW744X 10" Portable Table Saw
Dewalt D55155-QS 220 volts can it convert to use 115 volts?
The short answer unfortunately is no. The internal motor that drives this compressor requires 220 and will not work properly with 110. Your only option would be to replace the motor with one compatible with 110. The cost of that would approximate a major portion of a replacement unit.
Sorry about the bad news.
Dan
Jul 08, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Dewalt DW744XP 240V Heavy Duty Electronic Portable Table Saw Logo
43 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
