Question about Dryers
I have a whirpool cabrio gas dryer that igniter comes on and heats for a short time but won't relight
  • 106 Answers
Bill,
Could you be a little more specific? Does only the igniter come on, but no gas, or does the igniter come on, then gas, then it shuts off?
Posted on Oct 15, 2013
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
  • 14 Answers
SOURCE: dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Posted on Jul 25, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Posted on Dec 21, 2008
SolutionGuy
  • 331 Answers
SOURCE: AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Posted on Mar 27, 2009
SOURCE: Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Posted on May 30, 2010
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Cabrio model WGD6400SW gas dryer runs but not heating at all. have cleaned it.. still no heat. This happened the same day we had a service tech look at our cabrio washer. Have not had them for 3.5 yrs...
I agree. It's rotten to have someone check out your product and then have it stop working. You probably have a problem with your ignition panel.This is the part of gas dryers that gets hot. When it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Jul 31, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My Hotpoint gas dryer won't relight after it has
Your gas valve electrical coils have gone bad. They are easy to replace.
Jun 21, 2011 | Hotpoint Dryers
Whirpool dryer cabrio power comes on says sensing but won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 17, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Model 110 72712101 kenmore gas dryer will come on run about 2to3 minutes then goes off after a short the glow will come on again but will not relight.
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Here is a link to the parts you need.
Jan 02, 2011 | Kenmore 63942 Dryer
I have a whirpool dryer model LG5801XSWS GAS VALVE WON"T OPEN. TRIED A NEW IGNITOR. STILL WON"T IGNITE. HAVE POWER ACROSS LIMIT SWITCH PLEASE ADVISE
The next thing then would be the gas valve... it is rare but does happen that it goes bad...
heatman101
Aug 28, 2010 | Whirlpool Dryers
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
