Maytag washer a810
My Maytag A810 washer won't shut off. It runs through all the cycles perfectly, then when it gets to the final spin cycle it just keeps spinning. The knob does not move any closer to "off", stays pointing at "spin".
    Master:
  • 492 Answers
Sounds like a sticky timer
Posted on Oct 16, 2013
Testimonial: "Do I need to replace the whole timer? And do you know where I can find a walk-through to do this? Thank you so much!"
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test
to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Posted on Sep 17, 2009
dwrooker
  • 6 Answers
SOURCE: maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Posted on Oct 06, 2009
  • 12 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Posted on Nov 17, 2009
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Out of balance on spin cycle (machine is level)
The balancing straps that hold the drum in balance could be broken or the springs could be wore out.
Jan 11, 2010 | Washing Machines
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Top load washer
I am having this same issue, has anyone found the solution to this issue?
Oct 14, 2007 | Maytag PAV3240A Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
