Where is the reset button on a mitsubishi dlp 73' tv?
    Sergeant:
  • 259 Answers
  • Open the front panel by pushing on it. Pressing on the panel releases the lock and allows the front panel to pop open slightly. Pull the corner gently to open the panel completely.
  • 2
    Use a pointed object, such as the sharpened end of a pencil or the tip of a paper clip, to push the "System Reset" button.
  • 3
    Wait about one minute, or until the green LED light on the front panel display stops flashing.
  • 4
    Turn your television back on once the green LED light turns off.
    this is procedure for most mitsubishi dlp.
Posted on Oct 15, 2013
  • 1153 Answers
SOURCE: 73" rear projection Mitsubishi TV
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Posted on Sep 05, 2007
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
SOURCE: mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Posted on Sep 17, 2008
SOURCE: How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Posted on Aug 23, 2009
gopakumarg43
  • 74459 Answers
SOURCE: TV is 73" DLP Mitsubishi.
Hello
There are tow reaons for this fault. The first one is with the colour whell as you mentioned here. The second and most importan one is with its bulb itsef. Colour wheel won't cost too much. Just replace it first and see whether it helps you. If not, bulb may have to be replaced.OL
Posted on Jul 31, 2011
What is a dmd on a mitsubishi 73" tv
Howdy Mike-d. here,
I do not know what a DMD is on a Mitsubishi 73'' TV.
I did do a little web searching and here is a couple of things I came across.
From this website: http://www.tvserviceparts.com/Mitsubishi_DMDChips.html WD73833 ALL 4719-001997 DMD Chip, DLP, 1920X1080/XHD5, 0.65"/ DC4, TYPE X NON
I have no ties to these websites.
"I researched this and it was a DMD chip that needed to be replaced."
from this website: http://www.consumeraffairs.com/home_electronics/mitsubishi.html
Hope that helps.
Mike-d. out
mikedee4@gmail.com
Mitsubishi TVs and Electronics Mitsubishi TV DMD DLP Chip
Jun 27, 2014 | Mitsubishi WD-73833 73" HDTV
Mitsubishi wd-73c9 73" dlp tv
Here's what the Manual says about light codes for this TV. See Picture of actual page from manual.
Apr 13, 2014 | Mitsubishi WD-73C9 73" DLP TV
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
How do you reset the lamp hour meter on a mitsubishi tv
Consult the owner manual or if in a hurry call Mitsubishi customer service.
The owner manuals are widely available for free online.
Apr 23, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Can hear the sound on my 73 inch mitshubishi, but no picture at all..no black and white..nothing. After a few minutes the led red light in front that says "Lamp" comes on? What's the problem and how do i...
you need to replace the lamp inside the DLP TV. they are about $400 or so depending on your are. i would google the best price and find the must trust worthy TV repair place or call best buy.
Sep 17, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture goes black
have you tried the soft reset this model should have?
WD73827?
SD TECH
Dec 14, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
I have the tv in standard mode, but I am unable to
I bet you are using a cable box or satelite receiver. If so check for aspect buttons on the remote that control these devices. I know comcast says "HD Zooom".
Apr 21, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
