Question about RCA RCR412C Remote Control
Setting it uo
Can to tell me how to get the code to se ththis up to my tv 1 have a have tv
    Problem Solver:
  • 12 Answers
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
Push the t.v. button on the remote then push and hold the on/off button and the t.v. button down at the same time until the on/off button comes back on and stays on, then you release them both. Then push the CH+ or channel up button on the remote and the on/off button alternatively until the t.v. goes off or comes on, each time you hit the CH+ button on the remote you are advancing the code for you t.v. forward in your remote, after your t.v. comes on or off then hit the stop button on the bottom of the remote and you have stored the code for your t.v. Hope this helps.
Posted on Oct 21, 2007
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
I'm getting sound from my sharp tv when hook uo to my blu-ray player
If I understand when the blu-ray player is connected to the set you get the TV sound or what? If properly connected by way of a set of rear audio/video or component jacks to the same on the TV--you should if change the TV input to that location see the blu-ray and hear sound it sends out.
Component, composite, or what is the hook up between the two units?
Dec 05, 2012 | Sharp LC70LE640U 70-inch LED/ LCD TV
How do i check the fault codes on a carrier 8000
is ththis a package unit or residential split system?
Aug 26, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air is not building up pressure
There may be few causes for this.
1. The piston rings are worn out. If lot of oil comes in your receiver tank ththis is the indication to tell you that the piston rings and oil scraper needs to be changed.
2. The leaf springs strip is broken or worn out. If air is coming out of the suction filter open the compressor head with proper marking check and then fix back the same way you opened it.
3. One of the gasket is damaged or broken. Once again you will find air blowing out from the suction filter.
Aug 10, 2012 | Coleman Powermate 27 Gallon Air Compressor
QUIERO LOS CODIGOS PARA TV PHILIPS, SE ME PERDIO EL MANUAL DE INSTRUCCION DEL CONTROL UNIVERSAL DURABRAND 1 X CR2032. DESDE YA MUCHAS GRACIAS............ SALUDA ATTE. NOCHO VIALE
en la mayoria de los remotos universales viene una tecla que dice "CODE" si es tu caso:
1.- enciende tu tv
2.- oprime CODE y manten oprimida hasta que led indicador quede encendido
3.- pulsa tecla "POWER" las veces que sea necesario apuntando hacia la tv hasta que se apague.
4.- cuando se apague no des mas pulsos a POWER y oprime tecla "ENTER"
si por alguna razon te pasas y das un pulso de mas a POWER, repite la accion.
suerte.
Feb 16, 2010 | Televison & Video
I HAVE A NEW BLC320EM98 TV AND NEED TO PROGRAM TV REMOTE TO WORK ON "COMCAST CABLE". None of factory codes woek. What does?
In your packet there should be a set up sheet for the remote when you try to set it up follow the search guide for the remote to search and find the comcast box. Depending on how the search works on that remote it may take some time and you may find more than one setting that will work. Then you have to choose the best one that operates the comcast box the best. Good luck and be patient.
Oct 14, 2009 | Televison & Video
Setting up universal remote
Programala con la busqueda de codigo.
Enciende tu tv.,despues en el control remoto presiona la tecla code search hasta que el led se quede encendido luego presiona y suelta la tecla tv despues vas a tener que presionar y soltar la tecla power en el control remoto hasta que se apague el aparato una vez que se apague presiona y suelta la tecla enter para que el codigo se almacene.Puedes tardar un tiempo para localizarlo.Suerte.
Mar 02, 2008 | RCA Universal Remote Control
RCA RCR412C Remote Control Logo
42 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
