Question about Frigidaire FRFW3700LW Washer
Frigidaire FRFW3700LW0 makes a humming noise and does not drain.
  • 30 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
  • 6 Answers
SOURCE: Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Posted on Nov 18, 2009
pappapumpdaf
  • 635 Answers
SOURCE: Frigidaire front load washer LTF2940FE0 wont drain
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
Posted on Mar 18, 2010
  • 3 Answers
SOURCE: Frigidaire GLTF2940ES stopped with Error
Onthejob5130 is right, the machine use E23 too tell you that the pump is obstructed.
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Posted on Jul 25, 2010
What would cause a frigidaire front loader washing machine model # frfw3700lwo wouldnt spin?
Good Afternoon Friend, that's a great question!
If you are having difficulties with your Frigidaire washer (FRFW3700LW0) not spinning, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your washer.
Jul 24, 2014 | Frigidaire Washing Machines
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
Oct 11, 2012 | Frigidaire Washing Machines
Frigidaire frfw3700lw0 drains but not spinning
Hello ctilton2001 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 06, 2012 | Frigidaire FRFW3700LW Washer
My Frigidaire FEX831CS Top Load Stacked Washer / Dryer goes through the cycle till it gedts to drain, then nothing... pump out?
Hello trinileigh19 - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Hello, Frigidaire washer will not drain, its not clogged. makes loud humming noise when it should drain.
The drain pump has gone bad , it probably has a broken impeller. These units require you to remove the back panel to replace the drain pump assy.
Dec 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontload FWT449 will not drain water
clean the filter and or the pump.to drain lift hose out of outlet pipe and lower into a bowl
Jun 28, 2010 | Frigidaire FWT449
Turns on makes weird humming noise
The noise is most likely your drain pump trying to clear water from the sump area. If you remove the bottom screws holding the lower access panel in place, look for the drain pump and a block rubber hose connected to it. I suspect there is something preventing the pump from draining all the water. Remove the clamp holding the hose to the pump (have towels handy as there will be water) and clean out the sump, then put it back together and give the washer another try.
Mar 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FRFW3700LW Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
