Question about BH Fitness BH G6503 Mercury Avant Treadmill
Proform 6503 doesn't run - BH Fitness BH G6503 Mercury Avant Treadmill
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
My belt doesn't want to move when you turn it on. Do I need to replace it?
please lube the deck belt+rollers bearing front and rear+test the drive belt motor and replace if necessary.
God bless you
Jun 17, 2013 | Proform 795SL/GL760 Treadmill Front Roller
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
My proform 3.8 treadmill isn't running at the
see the diagram attached adjust the speed sensor, clean, and tight the connector very well.
2) Run after you did the adjustment the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 01, 2012 | Proform Exercise & Fitness
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
Assembled my ProForm 790T yesterday. I am using it with a TrekDesk so only ran it at 1mph and no incline yesterday. Worked fine. I noticed the belt was slightly over to one side, so I made a 1/4 turn...
DEAR
IF YOU DO NOT ANY MOVE YOUR MOTOR CONTROL BOARD IS DAMAGE
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 18, 2017 | Proform 790T Treadmill
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
BH Fitness BH G6503 Mercury Avant Treadmill Logo
24 people viewed this question
Top Bh Fitness Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Tom Chichester
Are you a Bh Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
