Question about Clover B7A Hot and Cold Water Dispenser
Won't dispence cold water. - Clover B7A Hot and Cold Water Dispenser
Freezer not cold
Best guess is your evaporator fan motor or defrost thermostat went bad.
Amana refrigerator repair in Orange County, CA
Feb 05, 2010 | Refrigerators
Works on hot not cold cycle
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 10, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Water won,t dispence from the freezer door. the water pumps to the bottom of freezer door,but don,t come out of the nozzel.
Water line in door is frozen. Set frzr warmer and leave door open an hour or so so it thaws out.
Nov 27, 2008 | GE Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE Profile Ice maker/ Water Dispensor not working
ok try this for me and let me know how it works there is a water tank in the fridge and on installation you have to hold down the water for about 5mins to fill it up now the ice disp will be a separate issue hold my rating and let me know if your water flowes first
Jun 13, 2008 | Refrigerators
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Clover B7A Hot and Cold Water Dispenser Logo
52 people viewed this question
Top Clover Water Filters & Coolers Experts
Tom Chichester
Are you a Clover Water Filter and Cooler Expert? Answer questions, earn points and help others
