Question about Combi Coccoro Infant Car Seat Carrot Cake
Replace cover the orange has collected alot of stains and they are hard to get out in the wash. how do i get anoyther one maybe in a different color
  • Combi Master
  • 1,629 Answers
Hi Jacqueline
We would recommend that you contact the manufacturer of the carseat in the country you're in for assistance.
Posted on Oct 27, 2013
Orange stains on clothing
I had detergent with oxy-cleaners do this.
murf427
Aug 01, 2012 | Maytag Washing Machines
Tip
Remove hard water stains from inside dish washer
one of the biggest problems with dishwashers, is the insides of it get covered with rust colored stains usually from the hardness of the water in your area.
the stains build up slowly from the water evaporating during the drying cycle, leaving mineral deposits on the interior of the unit.
By luck, I tripped upon a easy solution, thanks to one of my kids.
It seems she wanted to help out,and instead of putting dish washing soap in before starting the load, she put TANG breakfast drink in the dispensers.the citric acid seems to be the ingredient doing the trick.
Unbelievable, but true, the tang removed ALL of my staining, in one run.
give it a try, you'll be amazed.
TANG is a registered trademark of kraft foods.
on Aug 14, 2010 | Dishwashers
What kind of coolant does it require.
most newer vehicles are using this Dex Cool type that suposedly last to 100,000 miles, but the problem is it collects alot of grime in the radiator, its usually a little orange in color. for a while now there has been a big concern that the types cannot mix, and there right, because there is a different chemical make up in them all. but I suggest you use the universal type, its the safest for all systems and vehicles.look on the jug your about to purchase, and it should say (universal) on the front. hope this helps
Jan 03, 2011 | 2002 Jeep Grand Cherokee
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Mud stain
depends on what material is stained.. Aluminium stains can be very tricky to get clean if not impossible...some cleaners will also cause a orange/reddish stain wich will not come out unless you use some harsh chemicals to get them out. problem is it's hard to get to those chemicals. IF you happen to have a truck wash nearby where they wash the big trucks (18 wheelers)take your parts there and tell them to use some brightener on it , it's a chemical that really cleans aluminium.it may cost you a little bit of money but that stuff really works and i haven't been able to find that stuff for private sale anywhere. the number 2 reasons for stains on the bike are : 1) waiting to long to wash the bike , some types of sand/mud especially the red dirt we have down south here will stain a bike if you leave it on the bike , not only that it dries as hard as concrete and is very difficult to remove , so was your bike ASAP. 2) washing chemicals. Some chemicals / soaps when they are left too long on aluminium will leave stains as it reacts with the aluminium , these stains are almost impossible to get out.
Nov 10, 2008 | 2005 Vertemati E450
Mud stain
depends on what material is stained.. Aluminium stains can be very tricky to get clean if not impossible...some cleaners will also cause a orange/reddish stain wich will not come out unless you use some harsh chemicals to get them out. problem is it's hard to get to those chemicals. IF you happen to have a truck wash nearby where they wash the big trucks (18 wheelers)take your parts there and tell them to use some brightener on it it's a chemical that really cleans aluminium.it may cost you a little bit of money but that stuff really works and i haven't been able to find that stuff for private sale anywhere. the number 2 reasons for stains on the bike are : 1) waiting to long to wash the bike some types of sand/mud especially the red dirt we have down south here will stain a bike if you leave it on the bike not only that it dries as hard as concrete and is very difficult to remove , so was your bike ASAP. 2) washing chemicals. Some chemicals / soaps when they are left too long on aluminium will leave stains as it reacts with the aluminium , these stains are almost impossible to get out. ,,,
Nov 10, 2008 | 2003 Husaberg FS 400c
Mud stain
Nov 10, 2008 | 2000 Husaberg Fe 600
Mud stain
Nov 10, 2008 | 2000 Husaberg Fe 400
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Permanent (?) stains on inside of door
Have you tried a treatment (not sure of the name) that you wash plastic dishes with that takes the orange stains out? It can be found at Walmart for under $10. I don't know of anything that can prevent this problem but I don't see why a product that takes it out of plastic dishes can't take it off the plastic of the dishwasher. Hope it helps!
Sep 05, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Combi Coccoro Infant Car Seat  Carrot Cake Logo
44 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
