Question about Fleetwood Centrifugal Juice Extractor 1HP
How to replace motor basket shaft - Fleetwood Centrifugal Juice Extractor 1HP
Motor runs and is seem like it has a clutch that is slipping. Tried the re-set button. The re-set button does not seem to engage anything. Took the 4 screws off the bottom but do not see anything that...
The white impeller that you attached the basket and blade to is
keyed to the motor shaft. There is a small shallow nut that you
can remove with a needle nose pliers and pull the impeller off
the shaft to see if it's seated properly or damaged. If damaged
talk Waring into selling you another at 1 800 492 7464.
Apr 03, 2011 | Acme 5001 Supreme Juicerator Juice...
When I disassemble for cleanup, the basket is very difficult to get out of the bucket part. Any tips?
The basket may have cut into the hex shape top of the spindle creating little grooves which
the basket locks into. If that's the case you have to replace the part, it's called the impeller.
If you can purchase one from Omega, use a needle nose pliers to remove the flat hold down
washer/nut on top of the motor spindle, pull off the old impeller and push on the new. Line
it up correctly it only installs in one position. The impeller is the flat rotating part that the
basket sits on. I did it on my Acme but had to push a little for them to sell me one.
Nov 29, 2010 | Omega 1000 Juice Extractor
Hello I dropped my juicer and the motor works but shaft won't spin
Hello !
The stainless steel shaft might have misaligned from the motor bushing due to the fall.
But, It would be risky if you tried to open the motor assembly and realign it by yourself, a service man is usually the experts on this.
You can try first to lubricate the shafting with an oil and try to rotate it and see if it moves freely.
You can also inspect if the seal from the shafting is not broken. better replace it if you found one.
The bearing also is most like to be damaged and will need to be replaced.
This link might be helpful if you want to order parts from internet
http://ecommerce.hacres.com/Champion-Juicer-Body-Hub-Oil-and-Seal-White
Nov 23, 2010 | Champion 2000+ Household Juice Extractor
Replacement part needed
TRY 800 424 6783. PERSONALLY USING
A BREVILLE IS LIKE HANDLING A LOADED
WEAPON. MIGHT WANT TO CK OUT THE
OMEGA 4000.
May 06, 2009 | Juicers
Given a kenwood je500 juicer
email me at ewingelectrical@optusnet.com.au I have a PDF file that may help.
Apr 28, 2009 | Kenwood Juicers
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
Using the Citrus Attachment
CALL WARING AT 800 492 7464. MAY BE
SOME TYPE OF SAFETY CUT OFF. YOU
MIGHT ACTUALLY HAVE TO ATTEMPT
JUICING AN ORANGE OR SO WITH THE
NEWER MACHINES.
Jun 25, 2008 | Acme 5001 Supreme Juicerator Juice...
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
May 13, 2008 | Juicelady JL500 Juice Extractor
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Fleetwood Centrifugal Juice Extractor 1HP Logo
Top Fleetwood Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Fleetwood Juicer Expert? Answer questions, earn points and help others
