Question about APC American Power Conversion SUVTRT30KF5B5S - Smartups Vt Rack
Hello:) We use APC Smart-UPS VT, 30 kVA, Input
Hello:) We use APC Smart-UPS VT, 30 kVA, Input 208V 3PH / Output 120V (PN -SUVTRT30KF5B5S ). Our power module (PN - 0G-SUVTPM30KF) was crushed. We already fix it. After turn on power supply we can see error messages: 1) Int. Mech. Bypass Switch Closed. (bypass turn on now and we can`t turn off it, because our manufacture very important and we can`t switch bypass for free) 2) Later (after some seconds) display show message - System Failure Detected by Surveillance. So, corrective action in troubleshoot is Check for other alarms. Int. Mech. Bypass Switch Closed - Is it error? will be system use battery If i turn off mechanical bypass and power supply ? Thanks a lot:)
SOURCE: insufficient Runtime Available on Agent
If the UPS display is indicating runtime at 6 mins, and software is saying insufficient, seems like a communications issue. I'd try downloading the latest communication software for the UPS and reseating the communications cable at both ends, making sure no bent pins, etc. could be causing a comm glitch.
Posted on Jun 30, 2009
SOURCE: smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Posted on Aug 26, 2010
  • 173 Answers
SOURCE: An APC Smart 6KVA RT
your battery is damage,need to replace it with a new one.
your ups is overloaded. . .
Posted on May 11, 2011
epettingill
  • 175 Answers
SOURCE: APC Back-UPS XS900 shut down
Replace the batteries. Your UPS needs a little battery power to start back up. once the batteries are replaced all should be well
Posted on Aug 29, 2011
jvpacoin
  • 91 Answers
SOURCE: APC Smart-UPS 1500RM (sua1500rm) UPS System - charge lights flashing after changed battery
For APC smart-ups models, you need to do a UPS calibration after you change the battery. You need to change the UPS parameters to removed the flashing lights on the front panel of the UPS, usually you need to change the 0 parameter to its default state to remove the flashing lights.
Posted on Mar 25, 2012
Apc smart ups vt - no mains detection
be more precise
more info needed. what did you do. how did U startup the unit?
Mar 14, 2015 | APC Smart-UPS VT (SUVTP30KH3B4S) UPS...
How to find out damaged battery unit in 30kva apc smart ups VT?
pull them out, examine each one for cracks, bulging, leaking, then check the voltage. Should be around 12.25v fully charged.
Apr 19, 2014 | APC Smart-UPS 1500VA Shipboard...
Smart UPS VT 10KVA fault "Mains Not Available. Input Freq/Volt Out of Range". All phases input and output giving the expected voltages 240V and frequency OK at 50Hz.
Sounds like you hooked up the input to the UPS on the bypass. Either way either way your input is not there. Also make sure you configure the UPS prior to placing online.
Oct 04, 2013 | APC Smart-UPS VT 10kVA - SUVT10KH2B2S UPS...
Site wiring fault
Hi Viqtah, (<------ Clever!!)
If you hit the ESC key and get to the main menu there is a Setup submenu. In there you can change the line voltage values coming into the UPS. Sometimes a previous owner will change those values and cause the UPS to fault when properly connected. NOTE: A CERTIFIED ELECTRICIAN SHOULD VERIFY ALL CONNECTIONS ENSURE PROPER PHASE ROTATION.
Reply or call if you have any more questions -- 800.260.2259
Input Voltage
Setting must be from the APC PowerChute software
May 11, 2013 | APC Smart-UPS (SU5000RMT5U) (SU5000RMT5U...
Alarm #149 Service Battery
Contact vendor, that battery need to be replace..
Apr 04, 2013 | APC Smart-UPS 5000VA Rackmount with...
Inverter fault
This unit will require you to Brain dead the whole UPS.
To see if it is actually a condition that exists with the hardware or if it was just a lock condition.
Steps:
1)Power down unit completely
2)Unplug all batteries
3)Unplug from wall
4)Leave unplugged for about 5 minutes or so WITH NO POWER AT ALL.
5)Plug batteries back in
6)Plug back into wall
7) Turn unit back on
Log into console of UPS and see if the condition returns.
If it does not return your good to go.
If the error returns. You have to replace the WHOLE battery pack.
APC has told me their units are typically good for 4-6 years, after that their units cannot hold the same tolerances as they did when they were brand new.
Hope this helps.
Oct 30, 2012 | APC SURT8000XLT-1TF3 Smart-UPS RT 8000VA -...
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
APC American Power Conversion SUVTRT30KF5B5S - Smartups Vt Rack Logo
318 people viewed this question
Top APC Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
ray gallant
Are you an APC Luggage and Travel Expert? Answer questions, earn points and help others
