Connecting washing machine to water
I bought second hand hotpoint wmtl79-d/dg and there's no manual with it, I need to connect it to the water, and there's two water hoses I guess, why? And what do I do with it? I thought should be just one to put to the water spiurce? cheers Joanna
  • Washing Mach... Master
  • 3,361 Answers
One for hot water one for cold.
They both must be hooked up or water will run on the floor.
Posted on Apr 24, 2009
Wmtl79
is it spinning at all? if so then check ur pump for obstruction or bad propeller, if not check door switch, clutch, motor coupler, belt etc
Jul 09, 2014 | Hotpoint WMTL79 Top Load Washer
Mt WMT05 Hotpoint went mad whilst on spin, managed to find out that one of the suspension springs had broken, ordered some new ones and replaced both, it now spins ok but when put on wash (all the...
The tube goes to the pressure switch and to the bottom of the drum, if it is not connected the machine will continue to fill as the switch is not being told it is full and now needs to change to next part of wash.
Pressure switch is a circular unit located at the top of the machine and has a couple of wires to it.
Dec 21, 2012 | Hotpoint Wmt05p Wmtl79 Wmtl80 Washing...
No cold water coming out
Check where the hose connects to the washer sometimes their is a screen filter in their. If not the valve that controls the water input could be bad. Most of those valves are where the hoses hook to the washer.
Aug 22, 2012 | Hotpoint WMTL79 Top Load Washer
Can u run hotpoint wmtl79-d/dg washing machine just on cold water
yes it can be used only on cold water
if what your asking is that if you only have one hose to connect to it that cant be done the water valve where the hoses attach to must be capped off on the hot side or water will leak out of it
so yes only cold be used but must cap off hot side inlet at machine
Jul 21, 2011 | Hotpoint Washing Machines
My WMTL79 machine has a burned melted lid
Probably caused by a bad connection, or loose wire, nothing more serious than that .
Jan 25, 2010 | Hotpoint WMTL79 Top Load Washer
Hotpoint WMTL79 Top Load Washer. no water entering the drum.
Remove the front panel and open the control panel.
Remove the platic hose from the water level switch and the air dome on the side of the tub.
Clean the soap out of the air dome hole witha toothpick Blow through the plastic hose. Re-connect everything. Set the washer to spin and turn it on for 1 minute.
Then run a regualar wash cycle.
Mar 19, 2009 | Hotpoint WMTL79 Top Load Washer
Hotpoint aquarius wd440 confusion over washing machine pipes
Hi is there another valve? If so then you can connect them by a Y piece. Problem solved.....
Feb 26, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
