Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
I have a Sony Bravia LCD 46". The set is 1 year old. When I turn the set on in the morning the colors are blurry and run across the screen. This lasts no more than a minute , it just started doing this for almost 2 weeks now.
  • strangebrew3 May 07, 2009
    I have the same problem, but then three lines appear on my screen, this lasts for 30 minutes, then goes normal... its been going on for 3 weeks now.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    pls check the power supply socket thru voltage meter see if voltages are coming low
    Sniper:
  • 53 Answers
Could be 2 things:
1. Main board (BU board)
2. TCON board
Option 1: replacing the main board will run you a few hundred bucks for the Board and $300 in labor (or so) to get it installed.
Option 2: replacing the TCON means you might have to replace the whole screen (some TCONs are not available separately). A quick phone call or visit to Sony's part website will be able to determine which you need.
If you need to replace the screen, buy a new tv. The panels are amazingly, painfully expensive.
Now, there's a way to test which one is causing it, but you'll need to be quick.
For this experiment you will need: a screwdriver, a hair dryer, and some guts.
Take the back off the set, fire up your hair dryer and fire away at the TCON board (located at the top; it's a small board under a metal shield--you can't miss it).
Really warm up the metal shield and circuit board.
Now, plug in your tv and turn it on. If you don't see blurry colors and everything looks normal, you know it is the TCON board.
Posted on Aug 01, 2009
SOURCE: My Sony Bravia 46' XBR46 LCD has horizontal lines
I hope this helps it seems Sony has extended warranty coverage for your TV for this issue.
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Posted on Feb 04, 2010
SOURCE: Sony BRAVIA KDL-46XBR 46 in. HDTV LCD
I hope this helps
It seems Sony is extending the warranty on your TV
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
I had one vertical line it cam and went for awhile then stayed permanently and I took it in for repair only to be told they couldn't fix it now they are trying to give me a used tv (warranty don't want to pay) but I refuse I purchased it new and I told them I want a new one. I had that tv less than 2 years. So if you have a warranty and lines get it in fast.
Posted on Mar 26, 2010
SOURCE: My Sony Bravia 46" LCD turns pink randomly
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDL46V3000&news_id=245
Posted on Apr 06, 2010
budmrtn
  • 11361 Answers
SOURCE: Sony Bravia LCD black shadow screen
You may ahev failing T-CON board, try having a small fan blowing at the vent on the back of the TV. If you can post pictures it will help a lot.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 29, 2010
Can this be fixed ? what is the problem?
What your describing sounds very much like a video board issue some part is not working properly until it warms up. Eventually it will most likely need to be replaced, If you are not sure what board or part is bad, in the long run it might be a better idea to just replace the TV.
Oct 10, 2016 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Sony Bravia 46" It is 6+ years old and the color is completly out of reality has only blue,green and white and black . is this normal aging or fixable .
A faulty Tcon board is often found responsible for wrong colour type faults. Some times the main board is also found faulty. If it has happened all of a sudden, it is not aging.
May 07, 2015 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
When TV first turned on often has blurry dark lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Jun 26, 2017 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
I have a problem with my Sony Bravia. The screen is cut in half with a fine black line. The top section is the picture that continuely rolls and bottom section is lines of colors. It is 9 months old.
Depending where you got it It's probably still under warranty.I know Bestbuy usually offers 1 year free.My tv had red lines running through it and they said it was something to do with a climate part that they did not have so I was sent to pick out a new Tv.Good luck
Jan 12, 2010 | Sony BRAVIA KDL-46V3000 Television
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
May 19, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
SONY BRAVIA KDL-40S2010 40"
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Apr 08, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
928 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
