Question about Astar LTV-3201 32 in. LCD Television
My astar 32'' tv keeps switching to different channels by itself. what is the cause of this problem and how do I stop it from switching/changing to different channels on its own?
Hello, When your TV changing different channels it mean your TV main broad is defected. You needed to replace another main broad.
Posted on Nov 12, 2013
4 Suggested Answers
SOURCE: astar 32" lcd tv
No code yet.. still looking but the web page I found..
http://www.astarelectronics.com/
Posted on Jun 13, 2008
  • 16 Answers
SOURCE: 32"ASTAR problem
Please call 323-767-6030 and I will trying to help you as much as I can for the astar ltv-3201 tv.
Posted on Jan 31, 2009
  • 6 Answers
SOURCE: Astar TV shut itself off and never can turn it back on
did you check the power supply capacitors, all the models of astar had this problem. You can tell the bad ones because they are puffed up on top. This fixed my problem and many other peoples. They used cheap parts so cheap results, they are out of business
Posted on Apr 11, 2009
My 32" G.E. television can
I have had similar experiences. I have a VCR sitting near the television. I found that if I keep the VCR turned on then the TV stops changing channels by itself. If the VCR is turned off, then it starts again. Weird, but it worked for some reason.
Feb 15, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a sony tv and cant get sound on 3 different channels..the other tv in the house is fine
that's a weird one. You might check your audio settings to make sure it is not on SAP (secondary audio programming) sometimes that will cause lack of audio on certain channels since some have it and some don't
Jul 05, 2010 | Astar LTV-3201 32 in. LCD Television
Mind of it's Own
Astar LCD tv are famous using cheap capacitors in their power supply board as componnents,these capacitors are leaking gases,they bulges up,puff up.That why one ur tv is dead.The other tv is unstables changing channel on it own.U know basic electronics,and soldering?Take both of ur tv aparts.Searches all around the power supply board.Look for these bulges up,puff up capacitors,replaced these capacitors.Both ur tvs will work normal again.Or tries websites like Shopjimmy.com,Ebay.com to buy two whole refurbish power supply boards to replaced each one of ur tv.
Apr 29, 2010 | Astar LTV-3201 32 in. LCD Television
TV won't stop changing video modes
Remove remote in front of LCD and try with from LCD panel button press source button from your LCD tv
Jan 21, 2010 | Televison & Video
Channel keeps changing on its own
things to try:
1 look for a remote stuck in a couch(or other near place) that is barely peaking out enough to change the channel.
2. Check that the channel up or down button is not stuck on the tv and or any remote that is set up for it.
3. Find the tv's infrared sensor and cover it with your hand or tape. If the channel changing stops then something is emitting infrared that is causing it to channel hop (occasionally security systems can cause this to happen) also some kids toys. Anything that emits infrared light basically.
once you have found the source (neighbor with the same brand tv for example) or a remote with the cushion pressing the button for you. then you will should be good.
Sep 14, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
Mar 31, 2009 | Astar LTV-3201 32 in. LCD Television
Invalid Input-turning off seeting
I have the same problem in the office, but, not at home. I believe the IR sensor is confused by office florescent lighting, which has an unperseptible 60-cycle flicker not charactoristic of home incandescent lighting. Energy saving compact florescent probably have the same effect.
I have attached a dark tube over the sensor with relative success. This cluge is an unfortunate compensation for poor engineering because of the reduced angle of reception (the remote has to be directly in front of the sensor).
Dec 28, 2008 | Astar LTV-3201 32 in. LCD Television
I have a 32" Astar LTV ASB TV
Astar LTV-32ASB model problem? I know someone who's know more about astar TV. Just contact him at 323-767-6030 and maybe he will help you go through this problem.
Nov 30, 2008 | Astar LTV-3201 32 in. LCD Television
ASTAR 20" LCD TV Monitor - BLOCKED
I know more about the astar tv and models.
The only problem of this model of LTV-20PW is shows blocks when happen to some of channel on TV. Because of the bad reception or your location. To clear this problem is go to v-chip and clear off, menu, channel added. That should take care of it.
Any question please call 323-767-6030.
Aug 19, 2008 | Astar LTV-3201 32 in. LCD Television
32 astar tv
the tv remote has what you call a menu button press it and the menu will come.if you are using a universal remote you wont be able to get any menu most universal remote dont have menu features.if you do not have the originald remote press channel up and down together on the front panel of your tv and you can use the remote to acess what ever you want or the volume up and down button on the front panel of your tv.good luck.
Apr 01, 2007 | Astar LTV-3201 32 in. LCD Television
Astar LTV-3201 32 in. LCD Television Logo
97 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
