Question about Panasonic PT-60DL54J Replacement Rear projection TV Lamp TY-LA2004J / TY-LA2004
How to fix convergence problem on Panasonic PT-52LCX65 projection tv
SOURCE: Panasonic 52LCX65\PT Green Spot
I had the same problem. Panasonic sent somebody out to fix it...
Posted on Oct 09, 2008
ArnelM
  • 153 Answers
SOURCE: has a orange and green spot on screen tv is 3 years old
Call Panasonic and request for correction tool(software update) part#LSUQ0100. This comes with the instruction. Try this first before suspecting light engine.
Posted on May 27, 2009
SD Tech
  • 14553 Answers
SOURCE: Blue line Ghost Image on Panasonic Projection TV
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This set uses two Stk-392-110 convergence IC chips; both need to be replaced along with any of the 2.2. ohm light blue resistors around them; a bad resistor will be white in the middle; You can buy both for less than 13 dollars plus shipping on Ebay.
The chips are located on metal heat sinks with fins and are side by side. They are black(about 2 inches wide by 1 1/2 tall) and should have the STK-392-110 number printed on them in white.
Depending on your level of skill at this kind of work you may be able to do it yourself---if you need step by step instructions contact me---I have them in Microsoft word---start to finish repair including what you will need to do it.
If you are not able to do the repair yourself now is the slow time of year for TV repair shops----It should be fixable right in your home and the repair takes about an hour--I have done hundreds of these sets--some shops charge 300-400 but I do lots of them for 200-250 total cost. Make sure whoever you get changes BOTH of the chips!
Shop around and if they say "needs to go to shop" keep looking; any good tech can do this right in your home.
I do this here for free so if this helps you give me a vote here. If you need direct help contact me.
etower.766@netzero.net
Posted on Aug 27, 2009
SOURCE: Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Posted on Jun 14, 2010
SOURCE: Panasonic PT-52LCX65-K problem to turn on.
THERE IS A SERVICE BULLITIN BY PANASONIC IF YOU GO IN A PANASONIC SERVICE CENTER THE WILL CHANGE THE DEFECTIVE COMPONENTS IN THE BALLAST
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Dec 02, 2009 | Panasonic PT-52LCX65 44" HDTV
My panasonic rear projection pt-52lcx65 wont turn on replaced the bulb now what antbody ?
Sounds TV needs Ballast Supply board replacement, it is available in Part Store.
If you wish to replace above board by yourself, should have service manual copy that is available HERE for small fee.
Or call local TV tech for fix.
Thanks.
Aug 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Has a orange and green spot on screen tv is 3 years old
May 21, 2009 | Panasonic PT-52LCX65 44" HDTV
Resseting password
Try holding down the menu and power button at the same time for a couple of seconds. Every set is different but this may work on yours.
Jan 12, 2009 | Panasonic PT-52LCX65 44" HDTV
Yellow coloring on Panasonic TV
IN THE MENU FIND COLOR CONVERGENCE TO FIX THAT
Nov 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic 52lcx65 52in projection tv
I have the same TV had the same problem while under Warranty Panasonic tech replaced the lamp
Apr 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Red outlines and red lines on my panasonic PT-52LCX65
Good Day;
It sounds like you have a Convergence Circuit concern, with PAN replace with originals (STK392-110), using different "TYPES", ( that you may see on some sights, DO NOT), will draw too much current and you will have premature failure.
Good Luck, big IRISH.-
Jan 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-60DL54J Replacement Rear projection TV Lamp TY-LA2004J / TY-LA2004 Logo
27 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
