Question about Goodman GMS90703BXA Heater
Cracked heatexchanger or loose
When the main blower comes on it tries to blow the flame out which causes the rollout switch to kick out could there be a bracket sealing the heatexchanger loose letting the air in the heat exchanger
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Yes
Posted on Oct 20, 2013
  • 232 Answers
SOURCE: my heater works fine when its a little cold,when
do not adjust your gas pressure without an manometer or if you dont know what you are doing could be very dangerous. Roll out switches are manual reset if you have an open roll out on a Goodman furnace you probably have a cracked heatexchanger, get a qualified technician out there asap
Posted on Oct 07, 2009
Testimonial: "thanks for answering my question.your not the only one who told me that i was needing more than one persons opinion"
  • 89 Answers
SOURCE: GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Posted on Oct 08, 2009
  • 10 Answers
SOURCE: flame roll out, flat flames to the sides of the
may have plugged heat exchanger and or just very rusted burners pull off ventor box and make sure heat exchanger is clean remove burners and clean
Posted on Oct 17, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: replaced cracked heat exchanger on Goodman gas
It may help if you increased the blower speed. It sounds like you have a restriction in either the return air duct or in the heat exchanger. Does it help to open the blower door panel. If so, you have confirmed a restriction. How do the burners look? Are they good and blue or yellow? Are the correct orifices being used for the type of gas? I know I am asking more questions than you, but it may help us with the answers. Good luck to you Wade.
Posted on Jan 31, 2010
  • 1033 Answers
SOURCE: I have a goodman gpmn
Hello, looks like you limit switch keeps opening because your furnace is overheating, Check your air filter and blower wheel to make sure it is not dirty and make sure you blower motor is moving at the proper speeed. Usually when air flow is cutoff the limit switch will open.
Posted on Feb 15, 2011
Amana 80 sse flame rollout sensed what does this mean and how do I fix.
The flame rollout switch is located in the burner box on the left side on an upflow model. There are two wires connected to it .between the two connections is a small red button. Depress this until you here a small click. This should reset the switch. These
switches usually open because the flame is "rolling" back instead of being drawn into the furnace.start furnace and check for flame rollout.when the main blower fan comes on if you notice any change in the flame turn furnace off and call a qualified service person as this could indicate a cracked heat exchanger and could cause carbon monoxide to enter the house a potentially dangerous situation. I strongly urge anyone with a gas appliance installed to have a good carbon monoxide(CO) detector installed also. Hope this helps.
Dec 10, 2013 | Heating & Cooling
I have a goodman gmpno 60. I have a lot of flame rollout especially on ignition rolls all the way out the box. After ignition and before Blower kicks on still have flame rollout but is more after Blower...
This was my 1st thought after a crack. The fact the indoor blower affects it is a give away. I would get a carbon monoxide detector, if it goes off you have some work to do.
Oct 19, 2013 | Heating & Cooling
Heatexchanger
I would go to the goodman website
Oct 15, 2013 | Goodman GMS90703BXA Heater
I have a goodman gmpn that the middle burner has a little bit of flame rollout it kicks the flame sensor switch after about 1-2 minutes then it will not cycle back on. The flames are perfect until the main...
Unfortunately that means there's a hole in the heat exchanger, particularly in that cell of it. When the main blower comes on the air is pushed into the heat exchanger, causing the flame rollout. A heat exchanger crack or blowout is usually what condemns a furnace for good. Goodmans however, have a lifetime warranty on their heat exchangers, so you'll probably be able to find someone to replace it pretty cheap, or do it yourself for free.
Nov 04, 2011 | Goodman GMS90703BXA Heater
The furnace will start and run for 5 mins and kick off. Then the burners will not reignite after that. However, after everything cools down (about a half and hour later) it will restart and run for...
Hello, sounds Like the Furnace is tuning off due to the limit switch or rollout switch opening. A limit switch and rollout switch are safety swtiches that will turn off the furnace if it gets to hot or the burners flames are abnormal. Usually a weak blower motor, dirty blower wheel , dirty burners or even a crack in the heat exchanger can cause this problem. Best bet is to call a hvac technician and have them check it out.
Sep 14, 2011 | Heating & Cooling
Burner and pilot flames go out when blower kicks on
This is bad news you have either or hole or crack in your heat exchanger. When the blower comes on it causes flame rollout. Depending on age of age of unit it might be worth replacing the whole thing and getting the tax credit.
Dec 13, 2010 | Heating & Cooling
Rollout switch continues to trip
If you have a cracked heat exchanger this will cause the flames to rollout and trip this switch. Its meant to stop the furnace from running and putting carbon monoxide in your home. Watch the furnace as it tries to light if when the gas valve opens and flame is established it should go into the tubes heat the heat exchanger and then your main blower motor will come on. When your main blower comes on is usually when you see the flames rollout and trip that switch. If this happens you can either buy a heat exchanger or new furnace if its a older unit Obama still has that awesome tax credit til 12-31-2010.
Dec 13, 2010 | Goodman Heating & Cooling
Ruud gas pack cuts off after a short heating session. Only can start by resetting rollout switch. What could be wrong?
burners could be rusted blocking gas from getting across , so it pockets up and ignites all at once ,there also could be a partial blockage in heat exchanger but this is unlikely, or more seriously the heatexchanger could be rusted out with large holes in it so when blower comes on the positive pressure pushes flame back. either way when the roll out switch is tripped it indicates a pretty serious and potentially harmful issue that should be inspected and diagnosed by a reputible company.
Dec 02, 2010 | Ruud UAMB Air Conditioner
Does the burner On my Goodman PBG Package unit produce a fan shaped flame? Or, Are my burnes bad? I have flame inside the protection box where teh rollout sensors are, but the unit still works.
Sounds like you may have a major issue. If the flames are not going into the heat exchanger there is a possible crack that is pushing the flames out. What you need to watch for is before the fan comes on and after. If the flames are going in and then the main blower kicks in and the flames come out there is a problem in the heat exchanger
Dec 14, 2009 | Heating & Cooling
Coleman Evcon Furnace Model G8T10012UHB11A
you probably have a cracked heat exchanger which is causing the rollout switches to trip.even the tiniest of cracks will cause the fan to blow the flame back into the unit and cause them to trip. check the heat exchanger for even the tiniest of cracks if so replace it. and be sure to have a carbon monoxide alarm in your home.
Oct 25, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
24 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
