Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore 665.95012100 oven gets too hot - Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
You need to replace the "temp sensor" in the oven. Here is that part to order. Be sure to unplug the unit before doing any work on it!
Posted on Oct 16, 2013
Testimonial: "Hello Richard, When I was able to diagnose the oven on site I discovered that only the top element remained on without the oven control being turned on. It now appears the control board is at fault. When I unplugged the top element the oven was able to control the temp using only the bottom element. Thanks for your input."
Element in oven gets red hot, burns food being baked, will not shut off unless I unplug oven. how to fix?
You need a new thermostat or oven sensor. These people are pretty good but I am have trouble find details on the model number you gave. This gives an idea.
http://www.appliancepartspros.com/kenmore-range-cooktop-oven-fuse-sensor.html
Another place here
http://www.partselect.ca/Model-Number-Locator+8+repair.htm
Nov 15, 2015 | Kenmore Kitchen Ranges
Kenmore elite stove model #7909912949B. Can get anything to work on oven. Light comes one. Nothing else in the enter panel. Top burners work.
Can you enter the oven temp and press start on the control panel? Do you hear it click on, but it just does not get hot? Try turning on the broiler and see if the broiler gets hot.
Feb 01, 2015 | Kenmore Kitchen Ranges
My kenmore slide in oven gets warm but doesnt get hot enough to bake anything
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 25, 2011 | Kenmore Ovens
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
Kenmore Oven does not get hot
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 05, 2011 | Kenmore 30464 / 30465 / 30469 Gas Single...
I can't find my model number on my Sears Kenmore Gas stove. Several times now the stove has beeped then kicked out with EO and F2 showing in the clock area. The stove was bought in 2000 or 1999. Can you...
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
May 17, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
I am getting a E2 F2 code on my kenmore electric range model 95014102, pressing the clear button does nothing, I unplugged the stove and the code went out for a few days it is back on. What could be the...
The E2 F2 is an indication that the oven got too hot and shut down. If the oven actually got too hot the issue is most likely the main control board. If the oven did not get too hot the problem would be the sensor.
May 08, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
I have a Kenmore 9114012190 oven it does not heat properly anymore the top and lower elements get hot but it will hardly get anything warm that is placed in it ie; bread has to stay in it for 45 mins to...
start by checking your input power for a full 240volts,then check the terminal block for any burned off power input wires,then check power connections all the way thru the oven control and finally check for "hot-spots" in both elements(highly unlikely that both would be bad) its a discolored area that is a high resistance area not passing full operating power thru element(s)
Nov 19, 2009 | Kenmore 40192 / 40199 Electric Single Oven
Kenmore gas oven
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Apr 22, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
My oven is a kenmore gas single, self cleaning oven about 8 years old. the oven will not light. the top of the stove is fine.
Open the oven door and take the bottom panel off. you will be able to see it the hot surface ignitor starts to glow or not. Now turn the oven on and see if the hot surface gets red hot it not that is the problem. Should be able to get the part at a heating and air parts house or a appliance parts house. let me know what you find out. ken
Dec 13, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
50 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
