Question about Electrolux EL6984A UltraSilencer Green Canister Vacuum Cleaner
Singapore electrolux ultrasilencer plug fuse - Electrolux EL6984A UltraSilencer Green Canister Vacuum Cleaner
3 Suggested Answers
SOURCE: I have an Electrolux Ultrasilencer Deepclean
check the Fuse of the unit and see if replacing it will fix the issue.
Posted on Aug 10, 2011
bugoy31
  • 1238 Answers
Good day!!!!
that problem and faulty codes is cause of overloading due to difficult spinning of motor that usually cause of lock on lubrication...Please try oil the motor...
If you have any clarification and query regarding my solution...Just add a comment and I response you as soon as I read the comment..
Thanks for using fixya...
Posted on Aug 12, 2011
My electrolux T3530 will not start
Check fuse in plug and cable,but probably the motor.
Mar 07, 2015 | Electrolux Vacuums
My electrolux vitesse pet lover 1800w has stopped working
Is the flex all right? Check it with a voltmeter or a continuity meter (available for a small sum in your local hardware or electrical shop).
Jan 19, 2015 | Electrolux Vacuums
Overheats shuts off (protecto relay/)
The Electrolux vacuum hoses don't have a fuse of any sort incorporated into them. The resettable relay is in the machine they're connected to. In your case, judging by the shape of the machine end of the hose, your vac would be what was called a Special Model, with a Canadian type hose. These machines did have a resettable fuse in them which was supposed to protect the motor from overheating. If this feature is happening frequently, either the hose is partially plugged, or the motor is having a seriouis problem of it's own. It should be inspected by a qualified Electrolux technician, and they're getting harder and harder to find since they went to a franchise system of sales offices. Good luck.
Nov 09, 2013 | Electrolux electric hose models 2100
Cord won't stay out, it keeps going back in
when pulling the cord out, it should 'keep' it that spot if you pull a certain direction, cant recall if it is up, or down, left or right, and pulling it opposite direction releases the cord again
Mar 10, 2013 | Electrolux EL6984A UltraSilencer Green...
Green canister lid wont close
http://smallappliances.electroluxusa.com/en-US/Customer-Support/
download free your instr manual and see your problem lid why not close, go to the section troubleshooting.
God bless you
Sep 27, 2012 | Electrolux Ultrasilencer Green Canister...
How to clean a washable electrolux filter
Hi There,
Ok so i am going to assume you are talking about an Electrolux filter that is basically a rectangle shape with a hard plastic outer and folded corrugated filter material in the middle. The link I put to Electrolux filter would be a good example. Basically I would caution you against washing it. I know the packaging says that it is washable but what I have found is that the pores of the filter material are too fine for water to pass through. What will happen is that the vacuums suction will wedge tiny bits of dirt and dust in the pores and water will not necessarily flush it out. What is far more likely to happen is that it will wash out a fair amount but leave a portion in the filter to set and therefore continue to block suction.
You are better to use an air compressor or simply tap the filter out on a piece of newspaper and change it every year or so.
Of course if your filter is more like a Electrolux UltraActive filter which is basically foam then you simply rinse it out like a kitchen sponge and make sure it is bone dry before putting back in the machine.
Jun 26, 2012 | Electrolux Ultrasilencer Green Canister...
How do I take apart my electrolux ultrasilencer green vacuum to fix the retractable chord?
I would not recommend doing that. Take it to your local vac shop. They may or may not be willing to repair it. These machines were not built to repair. They are considered disposable. I have repaired these at my store but it is a very tedious task to get it apart without breaking all the tiny plastic tabs. You should give the local shop a chance before trying it yourself. They are better equipped for it.
Jan 08, 2012 | Electrolux EL6984A UltraSilencer Green...
Electrolux Guardian canister electrical problem
I believe there is a fused lead inside of the canister. Depending on where you connected your test light, you may have blown this fuse. I don't think you will have much luck finding aftermarket parts for this unit, so you may want to find an Aerus dealer. You can go to Aerusonline.com and use the dealer locater to find the closest store. Good Luck!
Dec 02, 2008 | Electrolux Guardian Bagged Canister Vacuum
Accidentally plugged into 220 volt outlet
The wiring diagram isn't showing a fuse, but there could be one on one of the circuit boards. Maybe the converter is bad. You will just have to take it apart and look it over. Maybe this pic. will help:
Nov 05, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL6984A UltraSilencer Green Canister Vacuum Cleaner Logo
63 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
