Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Washers doesn't work dE appeared, what does it mean....?
Mi lavadora da error fe
Posted on Oct 26, 2013
What does error code dE mean
Probably door (latch) Error.
Jan 31, 2017 | Washing Machines
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
Dryer function on De Dietrich washer-dryer doesn't work
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
Nov 05, 2012 | De Dietrich LZ9619 Front Load Washer /...
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
DE code, machine will not run. door working properly
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Aug 06, 2011 | LG WM2042 Front Load Washer
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
I turn on my washer and get DE on my screen, what does that mean
Hi
Thanks for using FixYa. DE is a door open error, you’ll have to check the door if it’s properly closed. Also check loose electrical connections at the door switch and PWB assembly. If everything appears to be fine then it is the door switch assembly that should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | LG WM-1832C Front Load Washer
My washing machine won't work.I keep gettting 'DE'.What does that mean?
Temperature sensor problem. Restart the load. Change settings on washer and test.
Aug 12, 2009 | Samsung SW62ASP Top Load Washer
Washing Machines Logo
50 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
