Question about Casio Edifice Watches
Half hour lag
My time is different between the hands and the digital time. I see there's a half an hour lag between them.
  • Casio Master
  • 7,993 Answers
Some watches can display dual times (two values) usually off by an integer number of hours + 30 minutes, Read the manual to set the digital display time then correct the analog display. Or just use one of the two.
Posted on Oct 16, 2013
SOURCE: tissot t touch, time problem
you need to calibrate it.
go to the '24h Cm' screen [T button, then touch centre screen few times]
hold down T button for 5secs
use + button to bring minute hand to 12 o clock position
use - button to bring hour hand to the same place
press centre of screen and it's done!
Phil
Posted on Aug 06, 2008
dmbgo
  • 58 Answers
SOURCE: the hour hand is not matching up with the digital time
Hi this means that the hour hand has slipped on its shaft, the watch needs to be taken apart and the hand removed and retightened and then reset in the correct position. It was probably caused by a sharp knock
You will need to go to a watchmaker for this
Cheers
Dave
Posted on Jun 22, 2009
  • 2501 Answers
SOURCE: T-Touch Analog time is 1 hour off digital time.
Go to "www.tissot.ch/" and at the bottom of page, click on "warranties".
Click on "user manuals" and enter details of your watch.
Posted on Feb 25, 2010
  • 2501 Answers
SOURCE: hands do not show same time as digital display
I have a Casio which had a similar problem and had to resort to reading he instructions to align the times!
I presume that instructions for your watch are not to hand but you can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Posted on Mar 20, 2010
mark_vici
  • 58 Answers
SOURCE: Hour hand does not match digital time
Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
Posted on May 03, 2010
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
My radio controlled watch is exactly half an hour fast according to the hands, but the internal clock appears to be correct. This happened when I tried to adjust the watch to Canadian time
If I understood correctly this watch have a analog watch display ..and it is half an hour forward..but when you set timing or the alarm it behave normal ..and so the internal one is correct ..but just do not display the correct time on the analog one ...If it do not have any means to correct manually the analog watch ..I advice to try to remove all power and stop the indicators at the exact time ...(a sharp hour...) and power it back after the exact time it is forwarded ....This way the analog clock will be stopped..and the internal one will go on and will adjust at the spot by the radio time ..and you will have both timers in correct display ...If it does have buttons or so in the back ..try to correct them by hand ..
Jul 12, 2011 | Watches
My Citizen Skyhawk analog UTC hour hand is alway 1 hour ahead of the UTC digital hour. I've tried reset and the hour/min hand alignment process without success. Any ideas other than sending in the watch...
You've gotta go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) or ON (for summer time). According to their website FAQ, they can't determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. Disappointing, I know. I just spent half an hour going through their website looking for some master switchover as well.
Mar 27, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Mantle clock does not give the right dongs I don't know how to set the hour dongs. half hour is right. It is key wound . What does the s-f key wind.
I had this very same problem with my mantal clock try seting the hour hand back to the hour dong repeat this untill the right hour dong for the time is correct this should resolve this problem
Jan 29, 2011 | Watches
I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
Hope this tip guides you to a solution for your clock.
r/ David
http://antiqueclock.clockstop.com/
Apr 06, 2010 | Watches
I am trying to set the time zone for Adelaide South Australia which is +10.30 hours UTC. Is thereany way to add 30 min steps to the UTC time setting
Set watch to CHR mode, pull out crown, all dials will return to 0 posn. HR shoul be displayed on left digital panel. Move hour hand by turning crown to posn half way between 12 and one, press top button (MIN should appear in left panel), set min to 6 o'clock posn. Push crown back in and set time for timezone nearest to where you are that is offset by one hour.
Oct 13, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Tag Carrera Twin time , second hour hand is not staying at time
The second time zone hand is running on a 24 hour face (right hand half of face is morning, left hand half of face is afternoon/evening) so all you need do is multiply what it points at by two. As an example, if your second time zone hand is pointing to the right (3 o'clock) then it represents 6am and if it is pointing to the left (9 o'clock) then it represents 6pm [9 x 2 = 18:00]
Apr 08, 2009 | Tag Heuer Link Automatic Chronometer...
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Tissot t touch, time problem
Phil
Jun 29, 2008 | Tissot T-Touch T33159851 Wrist Watch
Watches Logo
89 people viewed this question
Top Casio Watches Experts
Jimmy Accardi
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
