Question about Intel D945GCL Motherboard
My PC Restart - Intel D945GCL Motherboard
  • 11 Answers
There's not a lot of detail in your post....
Check the CPU cooler for dust, it might be overheating and causing the restart. After that try removing the RAM and see if it works better on only one stick of RAM - one of the sticks might be bad. Probably just dust on the CPU cooler and the CPU fan isn't cooling it off.
Blow the dust out with compressed air or you could try vacuuming it out with a plastic crevice tool.
Posted on Oct 15, 2013
My pc is not working. Giving me different error code each time I restart my pc
It is stuck in a boot you will need to contact your manufacturer and ask for recovery media. Good luck.
Mar 04, 2017 | Time Computers & Internet
Tip
Windows Vista password Recovery
If you have only one Admin account in Vista and have forgotten the password for the same and dont want to reinstall the operating system and land up loosing all your data, this tip is for you.
1) Restart the PC with the Vista Boot Disc.
2) Select Repair Your Computer option
3) Select the Command Prompt
Or - If you dont have a Vista Boot Disc then boot your PC to DOS using any Dos boot disk or other O/s disc.
4) goto "C:\"
5) Navigate to C:\Windows\System32 ( cd c:\windows\system32)
6) Now we will rename the utility manager to cmd.
Type the following commands,
- ren cmd.exe cmdold.exe
- ren utilman.exe cmd.exe
exit
7) we have renamed it successfully.
8) Restart the PC without the disc, reach the screen where you are asked for you password.
9) You will see a white blue icon on bottom left.
10) Click on the icon and CMD will open up, type the following command in CMD.
- net user administrator /active
exit
11) Restart the PC, and you will find you have one more administrator account
12) logon with the new account, goto user accounts and remove the password for your old account.
13) restart the PC with the Disc again, and goto the command prompt as we did in the step 1-3.
14) type the following command,
- cd c:\windows\system32
- ren cmd.exe utilman.exe
- ren cmdold.exe cmd.exe
15) restart the PC, and logon to your own account, open CMD by going from start menu.
16) type the following and restart the PC.
- net user administrator /active:no
17) restart the PC and now you only have one account and thats your own account.
on Dec 05, 2009 | Computers & Internet
Suddenly stopped working ,won't restart my PC?
First of all disconnect all peropheral connected to your motherboard. Take out Your RAM and clean it with soft clothe. Reinsert ram and restart your PC. If you can get display at this point then shut down your PC connect all peripheral back and restart your PC.
If not you will need to replace your ram.
Nov 29, 2012 | Computers & Internet
Asus eee pc auto-restart not possible
it could be an OS problem try to re-install (your OS)
Jun 14, 2012 | ASUS Eee 4G Notebook
Pc restart
to restart the pc you can either click the restart button(the small button next to the power button) or choose restart option in the shutdown menu.to access the shut down menu click alt+F4 from the desktop or choose turn off computer from the start menu
May 11, 2011 | Computers & Internet
Does not communicate with computer
Please disconnect it from the PC
uninstall the drivers, then restart your PC
then after you restart put the print disc in the cd drive of your PC
then once it prompt you to connect the printer connect your Printer to your PC
install and restart the PC
Your computer should have no problem in communicating with the printer
Jan 16, 2011 | Lexmark X6170 All-In-One InkJet Printer
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Over rang message on monitor
restart ur pc in safe mode
and make resolution to lower settings it will solve your problem
first restart ur pc
press F8 key continuously
it will shows windows boot option from their select start windows in safe mode
after booting up pc
right click on desk top
go to setting
make resolution to 800X 600 and and colour quality to 4 bit or lower
then apply
save it
and restart pc and it will show your desktop normaly
just in case if it wont work
do the same in VGA mode start ur pc press F8 and from booting menu
select Start windows in VGA mode
then do the same as safe mode
and restart your pc
Nov 25, 2008 | Computers & Internet
My windows alwyas restart & recovery bios
orangmedn
pc r restart for several reason like power supply problem, over heated, os problem. if ur pc restart when u try to access any drive or insart cd or dvd in drive means ur power supply is faulty. and if it restart after a fixed time (approximately) means over heated. (u reinstall xp so operating system is not infected.) if one of above symptom r their then no need to update bios.
2nd if some problem heppen during ur bios update and it not wirte properly and u restart ur pc in this situation the ur pc can not start and result is no display condition. if it happen then contact with any mother board repear centre or mother board service centre. (because if bios program r corrupt it need to repalce or rewite).
(**2nd time if u update any BIOS be Cautious. at first take backup then update. if any problem happen then restor with backup copy, then restart ur pc. until u sure update successfully do not restart ur pc).
Jul 10, 2008 | MSI PM8M-V Motherboard
Intel D945GCL Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
