Question about Vizio XVT472SV 47 in. HD-Ready LCD TV
All programmed remotes stopped responding. - Vizio XVT472SV 47 in. HD-Ready LCD TV
    Novelist:
  • 153 Answers
To turn off blue tooth on remote push the Q button, Space button and P button simaltaniously while pointing at tv.
Posted on Oct 15, 2013
Testimonial: "My remote has neither a 'q', a 'p' or a space bar."
The remote stop working
I would have the remote tested, shops use a tester, point remote at it and press buttons, if remote is working the tester responds. If you are using some type of programable remote and the batteries were removed it may need to be reprogrammed.
Dec 23, 2012 | Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
Do you have to reprogram the remote after changing the batteries?
It depends on the remote model.
After changing the battery please check weather the remote works or else you need to reprogramme it.
For programming please follow the below steps
1.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button.
2.Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV or DVD button.
3.Release it immediately and make sure the indicator light is illuminated.
4.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
5.If the device responds, you have successfully programmed your Philips universal remote.
6. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds
Thanx
Jul 25, 2010 | Philips Magnavox DVD/VCR Dual Player
Our devices suddenly stopped responding to the logitech signals.
If you removed the battery, you may have to reprogram it. will need the make and model number off the bottom of the remote, and what you want to program it to, (TV,--VCR,etc)...hope this was helpful..
Jun 02, 2010 | Logitech Harmony 880 LCD Remote Control
Tuner stops responding to remote though led
Well, if the remote has any kind of function working the set I would say the set is ok. Try replacing the batteries, if that doesn't help, then run to your local retail discount store and grab a cheapo universal remote, program it and see. If that fails then in the shop it goes. ( I doubt it tho )
Feb 01, 2010 | Panasonic Televison & Video
My devices suddenly stopped responding to my remote even though the remote looks to be working normally
Remove batteries, let it sit for a minuit then put in some fresh batteries.
Still not working?
Plug it back into your computer and load Harmony Remote software. Click on "update remote" this will reload the firmware and programming.
I've had a couple harmony remotes go wackey on me but normally re-loading the programming or putting in fresh batteries fixes em right up!
Cheers,
Kevin
Feb 01, 2010 | Logitech Harmony 670 LCD Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Feb 27, 2008 | Televison & Video
Remote problems
Take the remote to your local Radio Shack and have it tested.. They used to carry IR cards and now have a pen-like tester that can tell if the remote is operating properly. Then, if you're sure the code is correct, you probably will have to have the IR detector in the Tv replaced...
Bill
Nov 20, 2007 | RCA RCU300WBL Remote Control
Open Questions:
See all Vizio XVT472SV 47 in. HD-Ready LCD TV Questions
Vizio XVT472SV 47 in. HD-Ready LCD TV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
