Question about Brinks Locks & Locksmithing
I have a push-lock that can't be locked with the
I have a push-lock that can't be locked with the key, but the key unlocks...
  • 2,113 Answers
It likely requires powdered graphite or white lithium grease to lubricate it back to its original condition... or else try WD40 though it tends to be a more temporary fix
Posted on Oct 15, 2013
Why do my 2002 BMW 530i door locks inconsistently lock or unlock (front and/or back doors) when locked by electronic key signal or manual key turn in door but not when interior lock button is pushed?
Looking for PSD Fake ID Template? IDTEMPLATEPSD.COM is the number 1 source for PSD Fake ID Template! They offer top quality Driver License,Credit Card,Utility Bill,Birth Certificate etc. Instant delivery via email with excellent customer support . You can find them here- http://idtemplatepsd.com
May 01, 2014 | Cars & Trucks
I installed a bulldog remote starter with keyless entry and the doors won't unlock or lock with remote, why?
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
Jan 09, 2013 | Remote Starter with Keyless Entry
How do you lock it?
Hi Celsa,
Please follow the below instructions to unlock and lock depending on the series of sentry fire safe security you have.
H & F Series:
To unlock and open:
1. Insert key in lock and turn counterclockwise.
2. Apply downward pressure on top of the safe, while
pushing the latch in to release.
NOTE: Due to compression of the gasket, the
unit will require slightly more force
than a safe that does not have a gasket.
To close and lock:
1. Close and press down on lid to engage latch.
Safe can now be transported without locking it.
2. Insert key in lock and turn clockwise.
HD & FD Series:
To unlock and open:
1. Insert key in lock and turn clockwise.
2. Pull up from bottom
of latch while pushing
down on lid to release.
To close and lock:
1. Close and while pushing down on the lid, press down on
the latch until it is secure.
2. Insert key in lock and turn counterclockwise.
For the complete manual with images you can click on this link :- http://bit.ly/lzdBP2
Hope this helps.
May 11, 2011 | Sentry 1110 Fire Safe Security Chest
CHevy cobalt door locks- lock and unlock while I am driving had key fob reprogrammed and it was ok for about two hours and started all over again. What can the problem be?
Could be a problem in the shiftier. Your car doors lock automatically when you put the car in drive. They unlock when you put the car in park. The switch located in the shiftier can go bad causing the locks to randomly lock and unlock. Also, this can cause the key to get stuck in the ignition.
Oct 20, 2009 | 2005 Chevrolet Cobalt
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Un work of the doors auto control lexus
4. Shut door.
5. Open door.
10. Close the door.
11. Open the door.
13. Close the door
Long beep to follow if successful.
Programming used key fob for a 2000 tahoe
get in your truck close all the doors put your key in the ignition push and hold your unlock button on the door panel turn the key on then off then on then off release the onlock button at this time the lock should cycle lock then unlock by them self if they did push and hold your lock and the unlock buttons on your remote at the same time for 15 seconds the lock should cycle agian and you are programmed
Jun 04, 2009 | 2001 Chevrolet Blazer
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
Program my remote
Program your factory keyless entry functions
For 2001+ Tacomas equipped with a factory alarm or keyless entrymag-glass_10x10.gif, here are some programming options that allow you to adjust the way your locks work.
The first programming option allows you to set the entry unlock to: (A) unlock the driver door with one push, and the remaining doors with a second push OR (B) unlock all of the doors with a single push.
  • Open the driver's door. Remove the key from the ignition switch.
  • (Complete these steps within 40 seconds)
    1. Insert the key into and remove it from the ignition switch 2 times.
      (IN - OUT - IN - OUT)
    2. Close, then open the driver's door 2 times.
      (SHUT - OPEN - SHUT - OPEN)
    3. Insert the key into and remove it from the ignition switch 1 time.
      (IN - OUT)
    4. Close, then open the driver's door 2 times.
    5. Insert the key into the ignition switch and leave it in.
    6. Close the driver's door.
    7. Turn the key from LOCK to ON 4 times, ending at LOCK
      (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK)
    8. Wait for the locks to stop, then remove the key from the ignition switch.
  • On the key fob, press and release both LOCK and UNLOCK buttons at the same time.
    1. [For all doors unlock] press and release the UNLOCK button.
    2. [For driver door unlock] press and release the LOCK button.
  • Open the driver's door. The programming is complete. If programming did not occur, start over.
Jan 13, 2009 | 2001 Toyota Tacoma
Locks & Locksmithing Logo
97 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
