Jvc turntable will not return nor lift and reseat
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
I believe I just answered this. Again, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 09, 2013
2 Suggested Answers
SOURCE: JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Posted on May 26, 2012
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    I have a jvc jl-a20 auto return turntable and the arm briefly returns then proceeds to travel across the album. What do I have to do to get it to stay at home after it returns? Thank you
    It's probably some kind of mechanical problem. Perhaps something bent out of place.
    I have found a photo which is the underside of the model. You can compare it with yours and see if it looks the same. If it doesn't (assuming it is the same model) then you have found the problem.
    http://www.vinylengine.com/turntable_forum/gallery/image.php?mode=large&image_id=30141
    Oct 12, 2015 | JVC Audio Players & Recorders
    Jvc turntable JVC L-21a
    It can be any kind of mechanical problem causing the tonearm not to return to the rest. For more information, please visit my website at audioserviceclinic.com. Thank you.
    Oct 15, 2013 | Audio Players & Recorders
    Hi, I have a JVC AL-E11BK fully automatic turntable. I need to replace the belt. Could you please advice me on how to do it? I cannot lift the platter because of the centre clip. I don't know what to do...
    remove rubber pladder and use a flat blade screwdriver to remove the clip "carefull it may take off on you" next slide off the pladder, remove the old belt. Now! take the new belt put it around the inner part of the pladder, next put the pladder partly back on the center spindle and rotate until one hole lines up with the motor, take a hook and slip it under belt now carefully stretch over to the motor put on and push pladder into place and rotate it by hand clockwise to make sure it is in place, next reseat rubber pladder back on and power up to make sure it is working before replace the clip.
    Feb 14, 2011 | Audio Players & Recorders
    How to replace the belt on jvc l-f130 turntable
    You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
    Nov 22, 2009 | JVC AL A158BK Turntable
    Table does no rotate
    If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
    May 18, 2009 | Audio Players & Recorders
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    JVC turntable LA10
    The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
    Hope that helps.
    Mar 16, 2008 | Audio Players & Recorders
    32 people viewed this question
     Grubhead
    Grubhead
