Frigidaire frfw3700lw0 do not spin and bips a lot
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: frigidaire frfw3700lw0 drains but not spinning
    Hello ctilton2001 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
    Posted on Oct 09, 2012
    What would cause a frigidaire front loader washing machine model # frfw3700lwo wouldnt spin?
    Good Afternoon Friend, that's a great question!
    If you are having difficulties with your Frigidaire washer (FRFW3700LW0) not spinning, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your washer.
    Jul 24, 2014 | Frigidaire Washing Machines
    F93 eror
    What is the complete model number of your unit?
    Feb 17, 2013 | Frigidaire 30" Self-Cleaning Slide-In...
    Frigidaire frfw3700lw0 drains but not spinning
    Oct 06, 2012 | Frigidaire FRFW3700LW Washer
    Will not power on
    if all fan are spin up.
    see your RAM, maybe its broken.
    a computer need a routine checking all RAM, if its not good, your computer will freeze.
    try pull out and put it again. if its doesn't work. replace it.
    PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
    May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
    Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
    I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
    Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
    Non si vede niente dal monitor
    tre bip lunghi potrebbe essere un problema della tastiera.
    Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
    * Un bip = tutto funziona normalmente.
    * Due bip = errore POST/CMOS.
    * Un bip lungo ed uno breve = problema con la scheda madre.
    * Un bip lungo e due brevi = problema video.
    * Un bip lungo e tre brevi = problema video.
    * Tre bip lunghi = errore tastiera.
    * Lunghi bip ripetuti = errore di memoria.
    * Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
    * Continui alti e bassi bip = surriscaldamento CPU.
    guarda anche questo sito
    http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
    Dec 31, 2008 | Intel D945GCCR Motherboard
    Asrock K7S41GX "NEW" does not work :bip-bip-bip
    3 beeps is a memory error. remove the memory and put it in the first slot.
    also the memory replacement calls for ddr pc2700.
    Robert
    Sep 05, 2008 | Asrock K7S41GX Motherboard
    Drum makes loud noise when spinning
    HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
    Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire Washer Model # FWS1399EC
    The selector knob has gone bad. The selector will have to be replaced. I've seen a lot of Frigidaires with the same problem.
    Dec 20, 2007 | Frigidaire FWS1339A Top Load Washer
    Washing Machines Logo
    18 people viewed this question
    Top Washing Machines Experts
